dimension arrays in Swordfish
MrDEB
wanting to do this in a For NEXT LOOP but Swordfish uses only 1 demension unless I am going in wrong direction.Is this even doable??
[QUOTE
dim Channel(21) as byte
dim Channel(1) as portD.1
dim Channel(2) as portD.0
dim Channel(3) as portC.3
dim Channel(4) as portC.2
dim Channel(5) as portC.1
For x = 0 to 10
Channel(x) = 1
delayms(1000)
toggle (Channel(x)
next
][/QUOTE]
Not doable unless Swordfish has pointers to bits. Didn't you ask this same thing a month or two back?
yes I thought I did but wasn't sure I did.
doing some research because I have seen this done. Graham Mitchel has simlar in his Tetris code.
Thanks Burt, I saw your post before going to bed last night.
Going to try and load into a CONST array the values from 0 to 3 then load the buffer with the values. Each port will have a value from 0 to 3 for trial purposes on the Tap-28
Hopefully on the right track.
A SELECT CASE is basically a short version of IF THEN statements so this might work??
You are using 2 ports that makes it hard to do what you want.
You can change a whole port easy you can change bits too but
this doesn't work
You could use indirect addressing using AddressOf( )
But you'd be better with case and then just point to what case you want to use.
I started using CASE SELECT but would still like to use Led(1) , Led(2) etc.
looking at an example code where a data buffer was used.
First dim the ports DIM Led_1 as portb.0
then load a buffer Led_1 = Buffer(1)
want to play with this but Swordfish does not use more that 1 dimension arrays.
My goal is to use similar to PORTB.BITS(x) but may be asking the impossible??
No matter how many more times you say it, it's not going to work. Not even if you ask in 7 threads in 3 different forums. Oh, wait, you've already tried that.
I must have missed Mikes suggestion. Need to look at the << symbol.
will give it a try
Thanks Mike
I must have somethib wrong.
I tried Mikes suggestion and try to compile and keep getting EXPECTED on the sub route call
SUB light(led AS BYTE)
one minor issue I see is I am using 20 port pins on three different ports
Will come back to this later as I need to get some material cut for the town wide garage sale today.
You have typo'd or missed something prior to the line where the error is indicated. Something is missing in the line above, until eventually the compiler can't make sense of something. It could be a missing parentheses, a missing END IF for an IF statement & etc, a malformed command, etc.
You really should understand that after you've written a page of code.
Have a read
Swordfish doesn't support arrays of more than one dimension directly, but it's very easy to achieve the same thing using structures. The syntax is perhaps a little more convoluted, but the net result is the same. You will also find it to be more flexible, as structures can hold different data types. However, lets keep it simple and look at how we can create a 10 x 10 matrix of byte values.
Structure TArray
a(10) As Byte
End Structure
Dim Items(10) As TArray
The above code may look a little strange, but on closer examination it can be seen that Items() holds 10 structure elements, each with their own 10 byte array. To access an element, we simply use
Items(5).a(5) = 10
which is the same as writing something like
Items(5)(5) = 10
Here is a small code example which initialises a 10 x 10 matrix, then displays via the MCUs USART
// import modules...
include "usart.bas"
include "convert.bas"
// declare a 10 x 10 byte array...
Structure TArray
a(10) As Byte
End Structure
// local variables...
Dim i,j, Value As Byte
// initialise the two dimensional array...
for i = 0 to 9
for j = 0 to 9
Items(i).a(j) = i + j
next
next
// display to the screen...
setbaudrate(br115200)
for i = 0 to 9
for j = 0 to 9
Value = Items(i).a(j)
Write(DecToStr(Value,2)," ")
next
Write(13,10)
next
That's all there is to it. Passing your array to a sub or function is really easy also. For example, given the subroutine declaration
sub MySub(byref pArray() as TArray)
end sub
we can pass the array like this
MySub(Items)
Why don't you modify Mikes program slightly to look more like a two dimensional array..
sub toggleLED( led as byte, myport as byte)
    if(myport = 1) then
        porta = porta xor (1<<(led and 7))
    elseif( myport = 2) then
        portb = portb xor (1<<(led and 7))
    elseif(myport = 3) then
        portc = portc xor (1<<(led and 7))
    endif
Now you can use it as an array toggleLED( 5 , 1 ) .. LED 5 on port 1 ( A )
Here's an example that doesn't use arrays (need to research that), doesn't use const arrays (need to research that too), doesn't use complex statements like 'select case' or operators like '<<' (currently researching those), and doesn't involve 'C' (God help us, please don't research THAT!)
dim LED1 as PORTD.1,
    LED2 as PORTD.0,
    LED3 as PORTC.3,
    LED4 as PORTC.2,
    LED5 as PORTC.1
    // add more leds here
public sub set_led(ledno as byte, setting as bit)
    if (ledno = 1) then
        LED1 = setting
    elseif (ledno = 2) then
        LED2 = setting
    elseif (ledno = 3) then
        LED3 = setting
    elseif (ledno = 4) then
        LED4 = setting
    elseif (ledno = 5) then
        LED5 = setting
    endif
end sub
public sub toggle_led(ledno as byte)
    if (ledno = 1) then
        toggle(LED1)
        toggle(LED2)
        toggle(LED3)
        toggle(LED4)
        toggle(LED5)
    endif
end sub
dim x as byte
// make all leds outputs
output(LED1)
output(LED2)
output(LED3)
output(LED4)
output(LED5)
for x = 1 to 5
    set_led(x, 0)   // turn off led # x
next
for x = 1 to 5
    set_led(x, 1)   // turn on led # x
next
for x = 1 to 5
    toggle_led(x)   // toggle led # x
next
for x = 1 to 5
    set_led(x, 1)
    delayms(1000)
    toggle_led(x)
next
It's likely MrDEB won't even read this post.
Case Select is really not a "complex statement" and is in fact easier to use than a slew of If Then statements.
It's kind of how the world is today lets make it simple push button led comes on.
Na that to easy let's make leds light up and make a sign.
Na that worked but its like pushing a button.
lets write code that pull the letters out of a array and sets the pins sounds easy
Lets do it the way I want it to work forget that I didn't write swordfish and the help files with it and I'm sure it works my way.
See the problem is " dim Channel (1) as port anything is that when you do the next dim Channel (2)
the compiler see's Channel being used agin (X) is to hold bit , byte, or words value.
For most folks that's true, but for MrDEB it involves a lot of 'research' (ie search the internet until he finds code to copy that doesn't really do what he wants but contains one of the keywords he searched for so it's somehow close). Using anything past FOR NEXT, IF THEN, and simple assignments is dancing in dangerous territory.
After close to 10 years of watching his posts I don't think he's actually read or understood much of what's been told to him. Case in point is the first post in this thread. How could that possibly compile? What does it even mean?
Do you think there's any way a multi-dimensional array would solve his problem in a way that wouldn't eventually come back as gibberish?
