    Dismiss Notice
digital voltmeter by usb using ATmega8
Discussion in 'AVR' started by faraday, Jun 16, 2013.
  1. faraday
    faraday Member
    Dec 5, 2011
    51
    0
    HI all
    I wanna to measure an input voltage from -5V to +5V via ATmega8
    how can I use USB connection for that?
    the output goes to PC via USB connector
    and what is the circuit for this project?
  2. faraday
    faraday Member
    Dec 5, 2011
    51
    0
  3. kubeek
    kubeek Well-Known Member
    Mar 11, 2006
    1,488
    186
    Prague, Czechia (not Chechnya)
    the first thing is that to measure +/-5V you need a +/-5V supply, so you will need some chip to make the negative rail. Then you need to feed your measured voltage into opamp to translate it into the 0-5V range that the micro can measure.
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. dougy83
    dougy83 Well-Known Member
    May 18, 2008
    2,672
    215
    Brisbane, Australia
    You don't need a dual supply; a simple resistor divider will work.
    You can choose the circuit and base software that suits you best from the demo projects on the page you linked.
    • Like Like x 1
  6. faraday
    faraday Member
    Dec 5, 2011
    51
    0
    Hi
    thanks for replying, I did it by resistor divider and VUSB :eek:
  7. remon7
    remon7 Active Member
    Aug 3, 2013
    122
    55
    Malaysia
    • Like Like x 1
  8. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
    For that solution I would take a FT232 Chip. That's a USB to serial bridge.
    PC drivers are availible at the FTDI Homepage ( VCP Driver ).
    At Controller side You can use the Integrated USART. That will make the programming and communication easy.
Share This Page
