    Dismiss Notice
Detecting Source of RF
Discussion in 'Radio and Communications' started by Srinivasan T, Jan 10, 2016.
  1. Srinivasan T
    Srinivasan T New Member
    Jan 10, 2016
    5
    0
    Hi ,
    I detected one radio source at 2.4 GHz which is not Wi-Fi,bluetooth,microwave,dect phone.
    This source really unique.
    I need help on how find the source of the signal :
    1. Using SA with directional antenna
    2, lets say, if the source comes from satellite , how do we use SA.
    can we get , distance and coordination of the source !
  2. JimB
    JimB Super Moderator Most Helpful Member
    Sep 11, 2004
    6,328
    585
    Peterhead, Scotland
    How did you "detect" this RF source?
  3. Srinivasan T
    Jan 10, 2016
    5
    0
    basically using RF meter and Hack Rf
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. cowboybob
    cowboybob Well-Known Member Most Helpful Member
    Oct 22, 2011
    3,022
    477
    James Island, SC
    Welcome to ETO, Srinivasan T!
    What makes you assume that the signal you are "detecting" isn't WiFi?
    2.4GHz is a IEEE 802.15.4 COMPLIANT (2400 MHz to 2483.5 MHz) WiFi low end frequency.
    What characteristics of the signal qualify as "unique"?
  6. Srinivasan T
    Jan 10, 2016
    5
    0
    Well, Wi-Fi has round sound.
    This Source has different radio ,sound, waterfall image, etc.
  7. cowboybob
    Oct 22, 2011
    3,022
    477
    James Island, SC
    I'm not all that familiar with the HackRf SDR, but it is noted for frequency aliasing (10MHz increments) which could produce some FM variations that if detected might be misinterpreted as "intentional", as opposed to "incidental" signals.
    Unless you can capture and interpret the signal data, only suggestion I have is to triangulate.
  8. Srinivasan T
    Jan 10, 2016
    5
    0
    I have captured the signal using HackRF and the file format in .cfile.
    I don't know how to do anything with that file.
    If I have spectrum analyser with gps , waterfall , can the SA pin point the source.
    At present, the SA can pin point the source coming from ground but not sure about satellite.
  9. cowboybob
    Oct 22, 2011
    3,022
    477
    James Island, SC
    Whatever you are capturing, file problems may be related to the sampling rate of the HackRf (very high and a characteristic of SDR). This then might result in the data being saved as pure binary with the .cfile extension.
    As such, you'll have to extract and format that data before it may (or may not) be useful.
    Google "file format .cfile" - there are several stackoverflow threads concerning, in this case, GNU Radio.
  10. Srinivasan T
    Jan 10, 2016
    5
    0
    I have done lots of thing. so I need to know how to use SA with directional antenna to pin point the source. if the source comes from satellite
  11. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    If the RF is from a satellite then it should be stronger when the antenna is pointing up.
Share This Page
