    Dismiss Notice
detect breaks in metal fences
Discussion in 'Robotics & Mechatronics' started by nimasa, Jun 12, 2017.
  1. nimasa
    nimasa New Member
    May 20, 2016
    5
    0
    Hello,
    Do you have any idea how to detect cuts and breaks in metallic fences from 10-15 meters distance, except image processing?
    I'm going to use a drone for that. Is there any sensor I can use here?
    P.S. I think using image processing from 10-15 meters distance makes it so complicated to detect the pattern of fences and then detect breaks in between.
    Fence pattern may vary and it could include small squares as little as 4x4 cm for each fence to 10x10 cm for another. And I'd like to detect breaks as little as a circle with at least 20 cm diameter.
    Thanks in advance
  2. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,253
    1,218
    Cardiff, Wales
    Provided the drone kept the sensing equipment at a constant distance from the fence and flew parallel to the fence, in theory it might be possible to detect non-uniformity of the fence by bouncing a microwave signal off it and monitoring the echo strength. I doubt that this method would be practical though.
    • Like Like x 1
  3. Beau Schwabe
    Beau Schwabe New Member
    Jun 4, 2017
    20
    5
    .... Not if there is a way to use two cameras or two sections of the same image from a single camera and do a common mode rejection in the image. If you align the images so that pitch of the fence matches on a "good" section of fence, then moving to a break in the fence should show a spike in the signal to noise ratio. A simple way to do common mode rejection is to XOR the two images you are comparing. By XORing the two images all common mode data will drop off, and you are only left with the differences between the two images. You might have to roll your own code, but something like VisualBasic could even perform that type of operation on an image without too much headache.
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. dknguyen
    dknguyen Well-Known Member
    May 6, 2006
    6,668
    64
    Are these solid fences or wire fences? How big is your budget and weight limit?
    If you can handle $2000+ and about 1 lbs or 500g, you can use a scanning LIDAR:
    Examples:
    http://www.robotshop.com/en/hokuyo-ust-10lx-scanning-laser-rangefinder.html
    http://www.robotshop.com/en/hokuyo-ust-20lx-scanning-laser-rangefinder.html#Specifications
    But even those are just line scanners and 3D scanning is what you really want but that's even more cost prohibitive.
    There is this one but it is right on the border of your range limit so I don't know how reliable it would be, but it is 1/4 of the cost:
    http://www.robotshop.com/en/rplidar-a2m6-360-laser-scanner-16-m.html
    Does it also have to be a drone? I mean...it's a fence and you're looking at it from the side. It can't be an ground ROV? That would simplify processing speeds, stability, and payloads, etc quite a bit
    If it's a wire fence though...that'd be tough...
  6. Colin
    Colin Member
    Sep 25, 2003
    369
    21
    Australia
    It is very easy. Fit a very thin insulated wire along to the top of the fence and secure it at ever 300mm. Connect the far end to the fence and use a closed loop detector.
  7. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    7,253
    961
    Loveland, CO USA
    I think the wire is like this picture. You are looking for a hole or brake in the fence. So not easy.
    If the picture was as clear as this picture, I would try counting how many wires there is across the picture. OR Wires/meter. AND count five times across the picture.
    Where the chickens are it will be hard to see the wire. So missing one wire will be typical.
Share This Page
