    Dismiss Notice
Debug PIC18F26K20 with Pickit3
Discussion in 'Microcontrollers' started by Flyback, Jun 21, 2017.
  1. Flyback
    Flyback Well-Known Member
    Jan 5, 2007
    2,009
    34
    Hello,
    Our software works on some of our PCBs but not others.
    We program them with pickit3 and use ICSP.
    Can we just plug the Pickit3 into the board and debug it like that?
    When i try to debug I am getting "Connection failed" error in MPLAB X IDE. Do you know why?
    I have the 5 pin header in the pickit3 and its connected to the PCB.
    I actually programmed the board with this connector/wire assembly so i know the 5 lines are connected (MCLR,Vdd,Vss, PgD,PgC).
    In order to do debugging, do i have to program the PIC18F26K20 with the ".hlx" file instead of the normal ".hex" file?
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,302
    914
    Rochdale UK
    Are the programming pins used solely for programming??? Have you set MPLAB to debug through pickit3 ?
    • Like Like x 1
  3. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,869
    144
    morristown,tn
    You got set debug in the config word too and make sure lvp is turned off mplab x like to set that to on.
    • Like Like x 1
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,151
    337
    Brisbane Australia
    ONLINE
    The debug bit in config is automatically set/cleared by the IDE depending on the build configuration. If you can program but not debug then something is wrong in hardware. Capacitor on Mclr? Some circuitry on PGD/PGC?
    • Like Like x 1
  6. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    Well sounds good but maybe mplab X is acting like mine cause I've set it to use the pickit 3 and used the ccm to set pins and it's done funny things to the configure settings.
    I had to go back and change the configure on the chip the op is using and a pic 32 when i used the ccm
    I had about the same problem with this chip some times it would act like it wasn't working it had set to lvp and mclr turned off but that was using the ccm to set pins. witch don't work right some times I started reading the files ccm makes and change its mistakes or mine and it works fine after that.
    • Like Like x 1
  7. granddad
    granddad Active Member
    Jan 18, 2015
    762
    76
    Worcestershire UK
    Perhaps ICSP Wires too long ? Also put a ferrite core / block on the USB cable , make sure PK3 pin 6 not connected.
    • Like Like x 1
  8. phalanx
    phalanx Member
    Oct 22, 2003
    405
    7
    New Hampshire, USA
    Hi Flyback,
    I noticed you posted this exact question on the Sparkfun forums as the user "treez". You really need to follow up on your threads and provide the details people are asking for if you expect to get things squared away in a timely manner.
    -Bill
    • Like Like x 1
Share This Page
