Crossover frequency of a Buck LED driver depends on load?
Flyback
Hello,
Would the crossover frequency of a Buck Switch mode LED driver be lower in frequency if the load was changed from LEDs to a dummy load resistor of resistance (VLEDs/ILEDs)?
Are you talking about the corner frequency of an output filter? LTspice should be able to tell you.
Yeah, what do you mean by the crossover frequency?
Some LED drivers may not be able to start into a purely resistive load as that puts a load on the driver from 0v all the way up to the operating voltage while an LED puts a load on it from some starting voltage like 2.5v or so per LED in series.
crossover frequency is the feedback loop bandwidth.
Its where the gain crosses the 0dB line...as you know, the phase at this point should be at least 45 degrees, otherwise the converter could be prone to instability
Is this supply current output or voltage output?
