    Dismiss Notice
Could some have a look at this it's bit bang I2C
Discussion in 'Microcontrollers' started by be80be, Aug 7, 2017.
  1. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,869
    144
    morristown,tn
    For some reason it's not finding the WI2C.c
    Code (text):
    :: advisory: (1233) Employing 18F1220 errata work-arounds:
    :: advisory: (1234)  * GOTO instruction at reset vector must be preceded by NOP
    :: advisory: (1234)  * DAW instruction may improperly clear CARRY bit
    :: warning: (1273) Omniscient Code Generation not available in Free mode
    ../WI2C.c:12: warning: (520) function "_i2c_start" is never called
    ../WI2C.c:28: warning: (520) function "_i2c_stop" is never called
    ../WI2C.c:46: warning: (520) function "_bit_out" is never called
    ../WI2C.c:63: warning: (520) function "_bit_in" is never called
    ../WI2C.c:79: warning: (520) function "_i2c_wr" is never called
    ../WI2C.c:99: warning: (520) function "_i2c_rd" is never called
    ../WI2C.c:118: warning: (520) function "_ack_poll" is never called
    ../main.c:169: warning: (1464) number of arguments passed to function "_WI2C_wr_byte" does not match function's prototype
    :0: error: (499) undefined symbol:
        _WI2C_wr_byte(dist/default/production\I2c.X.production.obj)
    (908) exit status = 1
    nbproject/Makefile-default.mk:147: recipe for target 'dist/default/production/I2c.X.production.hex' failed
    make[2]: Leaving directory 'C:/Users/USER/Desktop/Clearning/PICI2C/I2c.X'
    make[2]: *** [dist/default/production/I2c.X.production.hex] Error 1
    make[1]: *** [.build-conf] Error 2
    make: *** [.build-impl] Error 2
    nbproject/Makefile-default.mk:90: recipe for target '.build-conf' failed
    make[1]: Leaving directory 'C:/Users/USER/Desktop/Clearning/PICI2C/I2c.X'
    nbproject/Makefile-impl.mk:39: recipe for target '.build-impl' failed
    BUILD FAILED (exit value 2, total time: 969ms)
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,305
    914
    Rochdale UK
    ONLINE
    You need to add this line at the beginning of main...
    #include "PIC16_I2C_BITBANG.h"
  3. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    I have it after
    Code (text):
    #include "xc.h"
    #define MAX_SIZE  80            // the maximum size for the arrays
    It didn't help even the code from microchip does the same thing. Before chip changes
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    I'm going to download xc8 1.31 and see if it works but on the fip side I maybe done wr0te better code using software peripheral-libraries.
  6. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    This seem to be a problem I download code for a microchip app and after 2 days it still will not compile that's with no changes I look at some new way to use the MCC to make I2C code it sits for a hour and never made a file lol.
    Then I fire up my arduino just to test if I have hardware right nothing happens.
    So I dig for a day and get that my I2c address should be 0x40 nope 0x20 nope 0x27 nope what the heck i finely find where some one had the same problem.
    It's 0x38 all 3 address pin to ground it's PCF8574AP so i got something working
    Going to look at Ian C tut for epprom
  7. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,324
    653
    Derbyshire, UK
    ONLINE
    There's an Arduino I2C example that checks all I2C addresses, and prints a list of all valid addresses it finds, it's easily ported to a PIC processor - and makes it simple to find out what address (or addresses) are on the bus. It can be VERY confusing when setting the I2C address, so it's nice to check that you're using the correct one.
    • Like Like x 1
  8. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    I just found where I went wrong on the address 7 bit not 8 bit 0111000 is 38 hex lol
    I was adding a 0 lol R/W
    I found one that tells if it's the right one " Arduino I2C example that checks all I2C addresses"
    didn't tell what it was tho.
  9. Ian Rogers
    Mar 28, 2011
    9,305
    914
    Rochdale UK
    ONLINE
    You are using MPLABX... I wrote a bunch of functions and they worked okay!! After several builds (no changes made ) they stopped building and reported a syntax error!!! There absolutely was no error... I copied the function that was giving the issue... Deleted and re inserted the exact same piece of code and low and behold.. working again.. The editor is a load of crap!!!
    • Agree Agree x 1
  10. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    Maybe that's what happening because I had the code working made some changes and my board didn't come on that's because of the address I tested that when I found my mistake i was using 0x40 it's 0x38
  11. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    Well I think I got it figured out now
    Code (text):
    void main(void)
         ADDR0=38;
         data=0x00;
        i2c_wr(ADDR0);
        i2c_wr(data);
        i2c_stop;
    while(1)
            // loop forever
  12. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    Well no errors but no output too
    Code (text):
    ./main.c:146: warning: (520) function "_ini_gpio" is never called
    Looks like they should be working
    Code (text):
    while(1)
        i2c_start;
        i2c_wr(0x38);
        i2c_wr(0x00);
        i2c_wr(0xFF);
        i2c_stop;
  13. be80be
    Aug 23, 2008
    4,869
    144
    morristown,tn
    It's alive thanks for the help
Share This Page
