Convert 0-12v to 0-5v
Mik3
Hi
I need a kick start with a problem I have with a LED dimmer circuit I have bought.
Its a touch dimmer that has 12/24v input and 0-12v output. I would like to convert the output to 0-5v to make it compatible with Mornsun KC24H700Rx2 analog dimmer circuit.
While I am not familiar with the Mornsun KC24H700Rx2 analog dimmer circuit if you have a data sheet that spells out the input impedance of what you are driving maybe this could be as simple as a voltage divider circuit? I would think simple divider before thinking voltage attenuator op amp circuits.
Ron
Are these normally PWMed - if so then a series resistor might suffice.
