    Dismiss Notice
Computer fan with 4 wires, 5 pin connector
Discussion in 'Datasheets, Manuals or Parts' started by Grossel, May 7, 2017.
Tags:
  1. Grossel
    Grossel Member
    Sep 16, 2008
    918
    22
    Norway
    Hi.
    I sit here with a 92mm computer fan that I pulled out of a scrapped HP server. The computer model name is "AFB0912DH", and is rated 12V / 2,5A.
    The wire colors is: Black, Red, Yellow and Green. The connector have 5 pins and the two first is shorted (both black).
    I will guess that black/red is power and the yellow and green is pmw/speed. The problem is that I cannot find any documentation on this, and I won't destroy the fan by pushing PMW input on speed output (because a search on ebay indicates that this fan is more expensive than regular computer fans).
    So it would be very helpful if anybody have a clue about the pin-numbers for a 5-pin can connector.
    [edit]
    Have done some web searches for "computer fan 5 wires", but I cannot find any that covers this type of connector.
    I found a site that have a picture of a matching fan:
    https://www.rakuten.com/prod/delta-92mm-12v-system-cooling-fan/286963397.html
  2. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,008
    316
    Brisbane Australia
    I have some fans here and they are Black, Red, Yellow and Blue. The yellow is sense and the Blue is PWM. Try powering it and look for a signal on one of the other wires, even a multi-meter on DCV will give a reading on the sense output, on Hz you should get RPM.
  3. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,810
    121
    Buenos Aires - Argentina
    Since the first two pins are shorted, this could maybe help you.
    From a test I did on what seemed a "standard" 4-pins connector PC fan, having the black wire on your left, I got:
    black - GND
    yellow - +12V
    green - tacho signal - 2 pulses per revolution (output)
    light blue - PWM ctrl (input - see below)
    The 3-pin fans may be used here knowing that you do not have the PWM control available.
    As per the governing standard (reccomendations?) the PWM control should be a nominal 25KHz signal (0 to 5V). Look for that standard to know about the "iddle" speed.
    Worth to note:
    Those PC fans get their voltage unaltered; control is via PWM.
    At the tacho output I used a 10K pull-up resistor to 12V.
    With no signal in pin 4, the fans goes faster.
    0V on pin 4 gets the fan running to a supposed "minimum" of 30%. (Read the standard).
    Steady 5V on pin 4 means NO change in speed.
    PWM ctrl (between 20 and 80% that my function generator allows) seemed to have a very linear response.
    Whatever you get, please post the outcome.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Grossel
    Grossel Member
    Sep 16, 2008
    918
    22
    Norway
    Thanks, hopefully I get time to test this. I must rig up a test bench, and I have several similar projects in plan.
  6. atferrari
    Oct 8, 2003
    2,810
    121
    My test took few minutes to connect things in a protoboard and maybe an hour to verify all stated in my post. I used a scope plus a signal generator.
Share This Page
