Out in my neck of Ozark woods, the only high speed bandwith option is satellite. the hardware is expensive, the monthly service is 50$ or more per month, and the speed sux. Hughes.net mite be a little faster than wildblue.net and the higher power punches thru rain better, but no VPN and there's problems with Linux.
Before that, I tried the long range wireless at 900 mhz, which worked... until the forest leafed out. Folks out here need a wireless link with a wavelength longer than wet pine needles. 400 mhz on down. And if you down in a canyon by a nice fishing hole, then 100 mhz or less. Nothing else will go over a ridge much less dip into the valleys.
Course, the ham operatators suggest packet radio. That's 9.6kbps, compared to 56k dialup. Helloooo?
Like steep forested mountainous areas all over the planet, there's lotsa dead zones with virtually no FM/VHF/UHF reception. If the population density was higher there'd be closer transmitters, but then they'd bring in the cable. With farms that average 200 acres, that'd be 1/4 mile of buried cable per user. Or more if there's an area of national forest.
But then, I thot of an RF tank circuit with the coil center tapped. No sin wave, no carrier, much less an IF. just a series of pulses, pos for zero, neg for one, with dead air for the stop bits. Since data varies so much between pos/neg, it wouldnt look like a sin wave, and regular tuners would ignore it. And with tuned Yagi on each end, say 12db, prolly get 15 mi on 5 watts, 50 mi on 20 watts.
Seems like I read about pulse detectors that'd pick up on it. A modern version of the 'spark transmitter' used on HMS Titanic. This seem reasonable?
