    Dismiss Notice
Car antenna adjustment
Discussion in 'Radio and Communications' started by lhtphoto, Jul 12, 2010.
  1. lhtphoto
    lhtphoto New Member
    Jul 12, 2010
    3
    0
    I have a 2008 SUbaru Outback wagon with the antenna built into the rear window. I need to "trim" the antenna at the radio to get a better signal. Does anyone know where the trimmer control is on the OEM radio/cd player?
  2. ermine
    ermine New Member
    Jul 18, 2010
    6
    0
    England
    didn't this just apply to AM days? The antenna was such a short length compared to the signal wavelength that you'd peak the aerial with a trimmer capacitor. Haven't seen that sort of thechnology for years. This thread has more about aerial trimming on car radios, sounds like its for old-timers only ;)
  3. lhtphoto
    lhtphoto New Member
    Jul 12, 2010
    3
    0
    I guess I'm an old timer but I do remember that FM segments at one time also had an antenna adjustment. The problem with the glass mounted antennas is that they can not be lengthened to assist with the lower end of the FM band.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. g1pgi
    g1pgi New Member
    Aug 18, 2010
    1
    0
    surrey
    if you look at the rear of the radio where the antenna connector plugs in you will see a small hole,this probably the antenna trimmer for the radio there should be a small slot visable,be very carefull adjusting the trimmer it is easily broken,a very small insulated screwdriver or better a small plastic rod with a filed flat end like a flat blade screwdriver,the trimmer is best adjusted at the high end of the AM band close to 1.5mhz(or 200Mtrs if your slightly older!!).
  6. lhtphoto
    lhtphoto New Member
    Jul 12, 2010
    3
    0
    Antenna trimming
    Thbanks for the input. I appreciate your help
  7. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,210
    640
    Derbyshire, UK
    ONLINE
    Bear in mind that the trimmer is for AM only, and not for FM.
    It also may well do nothing anyway, cars which use the crappy rear window as an aerial usually have an in-line ampliifer to try and make it work acceptably.
  8. RadioRon
    RadioRon Well-Known Member
    Oct 7, 2005
    1,755
    53
    BC, Canada
    Sometimes the trimmer is accessible through the front by way of the door where your CD or tape inserts into the player.
Share This Page
