    Dismiss Notice
Capacitor length/volume, does it matter?
Discussion in 'Repairing Electronics' started by halleffector, Sep 22, 2017.
  1. halleffector
    halleffector Member
    Jan 30, 2016
    98
    0
    I want to replace a broken capacitor in an ATX power supply for a desktop PC. The capacitor is 2200 uf, 10 V, so I find e.g. this one:
    http://www.ebay.com/itm/Free-Shippi...315952?hash=item2cba7d02f0:g:nccAAOSwRXRZQ0JF
    And I notice it looks like it is less than half the height of the original part.
    Does that matter? Can I safely use that capacitor as long as it is rated correctly capacitance and voltage, or do I need to look up other attributes as well?
    Why are some capacitors much bigger than others, yet rated similarly?
  2. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,611
    478
    L.A., USA Zulu -8
    Improved manufacturing processes may allow a reduction in capacitor volume for the same capacitance (assuming it's from a reputable manufacturer, which is an unknown for that ebay item).
    Those are probably okay for experimental purposes but I would buy a known brand for replacement in your power supply.
  3. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,295
    647
    Derbyshire, UK
    I would strongly suggest you use a capacitor from a good manufacturer, I usually stick to Rubicon or Panasonic - and using low-ESR ones is a good idea.
    There's a LOT of cheap crap capacitors about, which is why they fail so much - and a PC is likely to be full of the cheapest ones they could find.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,289
    1,223
    Cardiff, Wales
    Yes. You need a low ESR and a 105°C temperature rating.
  6. Chris Edwards
    Chris Edwards New Member
    Aug 28, 2017
    10
    0
    A capacitor of any size may be relatively high in capacitance and low in working voltage and vice versa. Small size capacitor implies a high dielectric constant and a high dielectric constant usually has some disadvantages in many cases.
  7. tomizett
    tomizett Active Member
    Aug 11, 2013
    428
    46
    UK
    I seem to remember something about tall thin caps being better at dissapating heat then short stumpy ones, but I can't rememberthe details...
    Rated ripple current (which I suppose is related to ESR) is another thing to considder, although you might not be lucky enough to find a datasheet for your original part.
  8. Mark G. Cooper Sr.
    Mark G. Cooper Sr. New Member
    Nov 5, 2017
    19
    0
    Nanticoke, Pennsylvania
    Nichicon also is a very high quality capacitor, I use them almost exclusively with very good results and long life.
    Best regards, Mark..
Share This Page
