    Dismiss Notice
Burnt solder flux, safe to use acetone?
Discussion in 'Repairing Electronics' started by halleffector, Jun 19, 2017.
  1. halleffector
    halleffector Member
    Jan 30, 2016
    98
    0
    Is it safe to use acetone to remove burnt solder flux? If safe, will it do the job at all?
  2. jpanhalt
    jpanhalt Well-Known Member Most Helpful Member
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    You might have better luck with a a mixture of acetone and absolute ethanol. I don't have a clue as to what the pyrolysis products are, but some might be a little polar and absolute ethanol is a great solvent for such things. Just a little water (5%) changes the solvent potency of ethanol greatly. Absolute will dissolve fat; 95% is much less effective.
    In short, try acetone. If that doesn't work (I suspect it may not), change to 50% to 75% ethanol (absolute or denatured) in acetone. My usual elixir for removing excess flux is that mixture (i.e, 75% absolute ethanol, 25% acetone). Isopropyl alcohol may work as a substitute for the ethanol. I just happen to have a lot of ethanol on hand.
    John
  3. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    i wouldn't try this on PCB - if you don't intend to remove the copper as well
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Been using the ethanol-acetone mixture for more than 20 years. Haven't removed any noticeable amount of copper.
    What do you use to remove excess flux?
    John
  6. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    possible , whats your technique?
    my sharp fingernails , then pure ethanol if i am to do more soldering otherwise i don't care as i'm not selling anything
    the "paint removers" do not cause the copper to fall off - but when you next time solder with high temperature and try to make a firm connection between Cu and bad quality component lead by "rubbing" the solder to surfaces with the welder tip and the Cu is small area it might come off easier than just with excess temperature - i usually cover everything with solder in prior sometimes it's not enough to sucessful finish
  7. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    Technique?
    I either immerse followed by toothbrush or just toothbrush alone for larger boards.
    I said nothing about "paint removers" -- a term that covers a very broad range of chemicals.
    John
  8. Pommie
    Pommie Well-Known Member Most Helpful Member
    Mar 18, 2005
    10,019
    317
    Brisbane Australia
    ONLINE
    That would be where you are going wrong. Save your welder for car repairs and paint remover for decorating. Neither should go near electronics.
  9. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
  10. jpanhalt
    Jun 21, 2006
    5,897
    502
    Cleveland, OH, USA
    ci139 : What's your point? Acetone does not remove copper traces from any PCB I have ever used. That gets back to your post #3. What evidence or literature can you present or cite to support your assertion?
    Since the OP asked in general whether acetone was safe, I stand by my response. I failed to mention, however, that if the PCB contains components that have "sensitive" plastic, like a plastic optical window, I will omit acetone from my brew and use just ethanol or isopropyl alcohol. That action is taken as an "abundance of caution." I do not know and have not tested the plastics used for such windows or LED's. Although, I have had no problems with ordinary LED's used to show an active state. Shrouded connectors and so forth have not been a problem. I would be concerned about using neat acetone on some of them, but as stated, I do not use neat acetone for removing excess flux nor recommend it.
    Additionally, with clear plastics, the effects of any organic solvent may not be immediate. Over a long time, the plastic may be more susceptible to crazing. One good example is acrylics (e.g., Plexiglas). It can be bonded with chlorinated hydrocarbons (e.g., chloroform), but that bond will show crazing years later. That is just one example, but relatively mild solvents like toluene or xylene or even oil-filled caulking can have the same effect.
    John
  11. ci139
    ci139 Active Member
    Apr 12, 2012
    398
    34
    and i said what i have experienced
    what i suppose to do now - try to remove a past evt. from world history - because it does not fit your like
    may be there are differences between acetone and acetone - or PCB and PCB - i don't know
  12. hyedenny
    hyedenny Member
    Jan 17, 2009
    68
    2
    Acetone removing copper??? Not a chance. Maybe you're thinking of Coppertone on asses?
    I've always had good luck with alcohol. What I've found to work even better, on suitable components, is household ammonia and a toothbrush followed by a rinse with water, then a good blow drying. Commercial processes often use aqueous washes.
Share This Page
