    Dismiss Notice
basic atmega328 circuit (without programmin/serial functionalities)
Discussion in 'Arduino' started by snaggy, Jun 9, 2010.
  1. snaggy
    snaggy New Member
    May 31, 2010
    8
    0
    I need to create a few cheap atmenga328 based circuits. These circuits I design and develop on the arduino 2009 board, but then when in production I don't want to waste the arduino board, so could you point me to a simple schematics that lists the bare minimum to make the microcontroller (previously programmed on the arduino board) work?
    I guess it should include oscillator, a few caps.. ?
    thanks!
  2. iard
    iard New Member
    Jan 23, 2009
    4
    0
    Romania
    You're right, if you don't want ISP, serial and the LEDs on digital pin 13 (PB5), power, Rx and Tx your circuit will need just this:
    - ATmega 328 (168 or even ATmega 8 are fine, depending on how big is your firmware)
    - 16Mhz quartz attached to XTAL1 (PB6) and XTAL2 (PB7)
    - 2 x 22pF ceramic capacitors for the quartz.
    A small bypass capacitor (0.1uF) between the power source and ground is always a good idea.
    Make sure you have a regulated 5V power supply.
    A push button between Reset and ground and a pull-up resistor (10K) between Reset and VCC.
    If you have even the simplest ISP programmer you can add a standard ISP 6 pin header.
    Good luck!
  3. Sceadwian
    Sceadwian Banned
    Oct 27, 2006
    14,047
    141
    Rochester, US
    In relation to your circuit once programmed you have only to look at the Arduino schematics. You'll have to replicate everything from the I/O pin(s) in question to the outside world, this includes the voltage regulator and any other Arduino specific devices which you may be using.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Norlin
    Norlin New Member
    May 9, 2007
    245
    3
    Lawrenceville, NJ
    You could use even less components if your application isn't timing critical by using the internal oscillator (8MHz). This would allow you to eliminate the need for the external crystal and two small capacitors.
  6. iard
    iard New Member
    Jan 23, 2009
    4
    0
    Romania
    I believe that most (if not all) of the Arduino libraries assume you are running at 16 MHz. For instance, if he's using I/O shield for serial communications or the Ethernet shield and the chips were programmed, as he said, on the Arduino board, even if his own application is not time critical, the libraries would not perform as expected.
  7. mayhem2408
    mayhem2408 New Member
    Jul 20, 2010
    2
    0
    Simply add #define F_CPU 8000000 into your sketch code and when it is compiled, all timed routines will be calculated on 8MHz.
    Also, if timing is not ultra critical but you still will high speed without modifying the F_CPU, you can use a 16MHz 3 pin ceramic resonator. This takes the place of the crystal and 2 caps. The timing is still usually accurate enough to run 9600 serial communications. Anything faster than that and the timing is usually to far out.
  8. cr0sh
    cr0sh Member
    Jul 10, 2010
    928
    17
    Phoenix, Arizona
    Also - lookup "standalone arduino"; this is the common term for what you want to do. BTW - it might be cheaper and quicker to go this route: Arduino Forum - $10 Arduino
Share This Page
