[B] how to generate a votage source whose load varies from 6kohm to 6Mohm. [/B]
deepakddp
hi friends,
can anyone pls help me with designing a ckt for a voltage source whose load varies from 6k:eek:hm: to 6M:eek:hm:
We need to know:
Is it mains or battery powered?.
Voltage Input/Output.
Is it DC or AC.
Current output required etc.
What is it for ?, we maybe able to recommend a solution.
Trouble is, we don't know the question.
Like to help
EricG
mr. EricG we want to design an ac ckt which generates a freq of 8khz with ac current at 28mV. and we want to measure the output voltage by varying the load from 6kohm to 6Mohm. we at first used a instrumentation amplifier but the variation in the output voltage was only from 6kohm to 40kohm. we dont know how to modify the ckt so that the output will vary from 6kohm to 6Mohm. it would be nice if you could help us with this problem.
I have a number of questions.
Q1. What waveform do you require, sine,square, etc.
ac current at 28mV
Q2. A current is measured in amps. milliamps, not millivolts.
Q3. The output voltage from what/where ?
Q4. Where is the load connected?
Q5. A voltage variation is not measured in resistance units.
Q6. What output and what is varying, what circuit ?
As you can see, as stated by Nigel, your request dosn't make any sense.
There are many members who would like to help, but we don't understand the question.
Quite often, a simple diagram, incuded in your written reply will help us to see what you are trying to do.
Regards
EricG
This isn't the latest incarnation of Walters?
hi hero,
Bring me upto speed , whats Walters ??
Regards
Eric
