attiny13 adc to pwm
giannhs
Good morning I'm beginner and needs YOUR assistance.
I have downloaded the program from below gist.github.com/adnbr/9289235 adc to pwm,and I want to convert the duration of pwm as the picture which presented YOUR,
.....................9,2m ...................0to500us
__.....................................................__
.. |________________________________| |______
here is the c code;
* PWM LED Brightness control for ATtiny13.
* Datasheet for ATtiny13: http://www.atmel.com/images/doc2535.pdf
* Pin configuration -
* PB1/OC0B: LED output (Pin 6)
* PB2/ADC1: Potentiometer input (Pin 7)
* ~100 bytes.
* Find out more: http://bit.ly/1eBhqHc
// 9.6 MHz, built in resonator
#define F_CPU 9600000
#define LED PB1
#include <avr/io.h>
void adc_setup (void)
// Set the ADC input to PB2/ADC1
ADMUX |= (1 << MUX0);
ADMUX |= (1 << ADLAR);
// Set the prescaler to clock/128 & enable ADC
// At 9.6 MHz this is 75 kHz.
// See ATtiny13 datasheet, Table 14.4.
ADCSRA |= (1 << ADPS1) | (1 << ADPS0) | (1 << ADEN);
int adc_read (void)
// Start the conversion
ADCSRA |= (1 << ADSC);
// Wait for it to finish
while (ADCSRA & (1 << ADSC));
return ADCH;
void pwm_setup (void)
// Set Timer 0 prescaler to clock/8.
// At 9.6 MHz this is 1.2 MHz.
// See ATtiny13 datasheet, Table 11.9.
TCCR0B |= (1 << CS01);
// Set to 'Fast PWM' mode
TCCR0A |= (1 << WGM01) | (1 << WGM00);
// Clear OC0B output on compare match, upwards counting.
TCCR0A |= (1 << COM0B1);
void pwm_write (int val)
OCR0B = val;
int main (void)
int adc_in;
// LED is an output.
DDRB |= (1 << LED);
adc_setup();
pwm_setup();
while (1) {
// Get the ADC value
adc_in = adc_read();
// Now write it to the PWM counter
pwm_write(adc_in);
very please to help me,use avr studio 5.0 mkll
