    Dismiss Notice
Atmega 32A programming help
Discussion in 'AVR' started by harikiran, Nov 30, 2011.
  1. harikiran
    harikiran New Member
    Nov 30, 2011
    6
    0
    hi friends,
    i'm a complete newbee to microcontrollers and their interfacing.i wanted to make a cellphone operated robot and i'm stuck with Atmega32A microcontroller programming.Please suggest me some programmer and programming software for Atmega32A microconroller.
    waiting for your help...........
  2. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
    There are many programmers for the ATMEL AVR Controllers on the market.
    I think the best Idea ist to use the original ATMEL AVR ISP MKII.
    As software you can use then AVR STUDIO 4. Unter the Tools you can find the Menu "Programm the AVR" Chose there your used Programmer and you can setup and Programm your controller.
    Most People i know use in system programming for the AVR Chips.
    Therefore must be connected MISO, MOSI, SCK, Reset, GND and +5V from controller and programmer together.
    At some chips e.g. ATMEGA128 would be used other pins for ISP Programming!
    Also you can use a JTAG Interface, or High Voltage parallel programming to put your Programm into the chip.
    Most Compilers have own programm download software included. You can use it too, when the used programing hardware was suported.
    • Like Like x 1
  3. mvs sarma
    mvs sarma Well-Known Member
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    reach out www.circuitsworld.com
    and he has a ready made USB programer. It also supports ATMEL89S5x series
    Hope this serves your needs. Otherwise you need to make a comport based programmer at home using the schematic from www.ponyprog.com
    the serial version has facility to work either from derived Vcc or external Vcc.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. harikiran
    Nov 30, 2011
    6
    0
    Thankyou to mvs sarma and wkrug.I just tried the circuit shown in ponyprog using parallel port.i have a doubt .does it require any external power supply for the microcontroller and is it necessary to place the oscillator of 4Mhz.please help me with complete description about connections.i used the following circuit diagram[​IMG]
  6. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
  7. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
    Newer Programmers use a 6 pin Female Header for ISP Programming.
    So you have to Install a 6Pin Male Header on your PCB.
    That save Place on the PCB and is compatible to the AVR ISP II.
    Connections:
    Pin - Signal
    1=MISO
    2= +5V
    3= SCK
    4=MOSI
    5=Reset
    6=GND
    I know the Ponyprog Programm, it was my first programming tool, but the support is out of time.
    Newer Versions of the AVR Controllers will not be supported.
    VISTA or Windows 7 support ??? not shure.
    I'll suggest you to use a USB Programming Interface, because newer PC's and Laptops have in Future no more serial or parallel Ports.
    The newest Version of AVR Studio 5 has an integrated C-Compiler, but it needs very much system Resources and is very complicated. I use AVR Studio 4 at time.
  8. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    Well said. http://www.fischl.de/usbasp/ has usbasp programmer they have implemented software USB in either ATmega8 or ATmega88 chip and the programmer is working fine. needed firmware is given there.
    later some enthusiasts made changes to firmware to accommodate atmel89S5x also into that without any hardware changes.
  9. harikiran
    Nov 30, 2011
    6
    0
    can't i use the circuit above i.e for a parallel port
  10. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    you can be happy to use usb port i suppose.
  11. harikiran
    Nov 30, 2011
    6
    0
    For a awhile I have been away.Searching about what you have said i found it's too costly(for my budget).so can you please suggest me a simple and cost effective Programmer so that i can make it at home.I have both serial port and parallel port.I already made the circuit above but it is not working please help me......... thanks in advance
  12. harikiran
    Nov 30, 2011
    6
    0
    And one more doubt.Are atmega32 and atmega32A similar.i.e. can they be programmed in similar way.can i burn the hex file created for atmega32 to atmega32A.thanks once again
  13. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    Kiran,
    let us examine how it becomes costly?
    the loading firmware is free. the chip ATMEGA8L is sold below 100/- usb socket and pcb and few components including crystal should not cost you more than say Rs100. Yes, you have to make a PCB of course.
    All said you get your programmer working for Rs 250 or below.If you still can't or don't want to spend,
    Let me think to suggest you a serial loader or some such thing.
    PS:i remember i had already suggested this link to you
    http://www.lancos.com/siprogsch.html you have to use the first element and one of the remaining elements to suite the chip you are programming.
    it is the cheapest option. All the best.
  14. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    please try to study datasheets, - an advise i am not supposed to give , LoL
  15. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
    The easyest i know is a parallel port programmer.
    It consists only from a Port Connector an a few bridges there.
    But there is no Protection for the parallel Port.
    A quite cheap solution for USB is this one http://shop.myavr.de/index.php?sp=article.sp.php&artID=200006
    I'v no experience with this programmer.
    For all programmers you have to search for a software that fits to the programmer.
    With AVR Studio or Ponyprog you can operate nearly every programmer.
  16. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    Nice item wkrug.
    Its landing cost works to around 25 Euros and as per our currency it should amount IN Rs25*70=Rs1750/- but if he can spend Rs250, he can make a decent USB based Programmer sitting at home. the whole issue , as I understand, it is of one time job for him to lad after which he might never need it. Perhaps the best for him is too use a facility at his college or University. get it done and forget.
    even the si-prog is so simple with internal derived power from com port, that he could breadboard, test and plug the chip load and forget.
  17. wkrug
    wkrug Active Member
    May 30, 2010
    271
    29
    Germany
  18. vsaar
    vsaar New Member
    Dec 31, 2011
    23
    0
    Finland
    You can buy a USB programmer from eBay, prices starting from just $5. Search for "avr programmer". I have one of those and it works great.
  19. Umesh Lokhande
    Umesh Lokhande New Member
    Sep 29, 2015
    2
    1
    You can use Atmel Studio 6.2 or any other IDE along with USBasp Programmer. Insted of wasting time and writing things back again. Here are bunch of great tutorial page and YouTube channel with great deal of details. (STEP-BY-STEP GUIDE)
    YouTube Channel: https://www.youtube.com/playlist?list=PL4pptAPY2kIeCFdU__MYsDeuy6Thso8at
    Tutorials Series: http://www.binaryupdates.com/avr-microcontroller-tutorials-declaration/
    I hope all this could you help you to learn programming AVR Microcontroller.
    Have a Fun Microcontroller......Happy Programming
    Good Luck
Share This Page
