    Dismiss Notice
ASM file from keil c program?
Discussion in '8051/8951' started by Navid, Jan 31, 2015.
  1. Navid
    Navid New Member
    Jan 9, 2005
    17
    0
    Hi friends
    How can I get ASM file from my keil C51 program? I have list file and i see asm program on it but I want asm file itself!!
    Is there anyway to get asm file of my c program?
    Regards
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,165
    910
    Rochdale UK
    ONLINE
    I don't know about keil, but almost all compilers spit out an ASM extension... If you look through the documentation, you'll probably find a command line switch..
    • Thanks Thanks x 1
  3. Navid
    Navid New Member
    Jan 9, 2005
    17
    0
    I found that i can right click on the c file and select options for file and check src assembler file. but i have still a problem, some asm routines are not on code and it use extrn code 'routine'
    I do't now where can i but that routines, for example i want routine of 16 bit division that i see it on debuge mode on lst file but it's not on src file!!
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Wade Hassler
    Wade Hassler Member
    Jun 4, 2009
    152
    11
    The 16-bit division code, and much else, is in an object-code library that you did not write.
    Some compiler writers/vendors do not want to give that code away.
    If you really can see the assembly-level code in the *.lst file, then it might be some work to obtain it in (re-)compilable form, but it can be done.
    • Thanks Thanks x 1
Share This Page
