    Dismiss Notice
Arduino Coding for LCD display
Discussion in 'Arduino' started by Amy KL, Oct 20, 2015.
  1. Amy KL
    Amy KL New Member
    Oct 13, 2015
    2
    0
    My project is dealing with 4 FSR sensors with arduino. I would like to display the pressure level of all 4 sensors inputs on a LCD screen all at once. I've written the codes by referring to relevant sources, but I'm uncertain if my coding is functioning as I'm completely new in this, wish to hear some comments on these, thanks.
    #include<LiquidCrystal.h>
    Liquid Crystal lcd(12, 11, 5, 4, 3, 2);//set pins for LCD
    int fsr1 = 0;//fsr1 connected to analog pin 0
    int fsr2 = 1;//fsr2 connected to analog pin 1
    int fsr3 = 2;//fsr3 connected to analog pin 2
    int fsr4 = 3;//fsr4 connected to analog pin 3
    //variables for level of force applied to FSRs
    int fsr1level = 0;
    int fsr2level = 0;
    int fsr3level = 0;
    int fsr4level = 0;
    void setup()
    lcd.begin(16, 2);//set up LCD no.of columns & rod
    void loop()
    //divide by four as analog read is 4x sensitive as digital
    fsr1level = analog Read(fsr1) / 4;
    fsr2level = analog Read(fsr2) / 4;
    fsr3level = analog Read(fsr3) / 4;
    fsr4level = analog Read(fsr4) / 4;
    //display pressure level on LCD
    lcd.setCursor(0, 0);
    lcd.print(fsr1level);
    lcd.setCursor(15, 0);
    lcd.print(fsr2level);
    lcd.setCursor(0, 1);
    lcd.print(fsr3level);
    lcd.setCursor(15, 1);
    lcd.print(fsr4level);
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    The correct syntax for reading the A0 analogue pin is..
    int FSR1 = A0;
    analogRead(FSR1);
    You have a space in between analog and Read... ( Syntax error )
    Also It would be preferable to use A0 rather than just 0... ( Readability )
  3. MrAl
    MrAl Well-Known Member Most Helpful Member
    Sep 7, 2008
    11,026
    951
    NJ
    ONLINE
    Is something not working?
    It looks like you are set up for parallel 4 bit operation?
    The code setCursor(0,1) refers to the first character, first line
    The code setCursor(0,2) refers to the first character, second line
    The code setCursor(0,N) refers to the first character, Nth line.
    So you are using 4 lines. These are usually referred to as "rows" not "columns".
    Does x=analogRead(0) even work? I think it has to be x=analogRead(A0) for example.
Share This Page
