Amplifier
john89
Hi
I have a JFET transistor, and I want to determine the values of the resistors R_3, R_4, R_S and R_D, so it has an appropriate operating point.
I have found R_S, R_D and a relationship for R_3 and R_4
R_4/(R_3 + R_4) = 1/6
I also know that
U_ut/U_in ≥ 0.995
I want to find another value or relationship for R_3 and R_4, so I can solve it.
U_GS = Voltage Gate Source
Do you really intend for source and drain to be tied together?
If so it is just a Vgs voltage clamp, not an amplifier.
sorry, there shouldn't be a connection there.
However Ive started to think whether its better to use the R3 R4 relationship and just choose for ex R4 to 2Mohm and then solve, its supposed to be high resistans.
Looks like a source follower. Rd can be zero ohms.
You usually want source to be near mid-supply for max output swing. Actual best swing is when source is supply/2 minus half Vgs. Gate will be half supply plus half Vgs. The value of Rs will set the current through device. Add Vgs to Vs to set the R3/R4 divider. JFET will have very small, nanoamps, of gate current so don't have to worry too much about gate bias current.
