alarm house 16f877 ?
I program with winpic800 and icprog.
programming is normally ok at the end.
reading the 16F877 is also normally
when I delete the pic is also good.
reading indicates 3FFF ... ... so it's good 3FFF
but I do not understand why the pic does not work with any program! ?....
my 16f877 -----> Imageshack - 16f87720p
blueroomelectronics I can not find ? thank.
..... hex if possible i have difficulty
convert asm.to .hex
convert asm.to .hex
Use Mpasm to generate the hex file from the assembly code...
You can download Mpasm from Microchip's website
I use MPLAB v8
I never managed to create a. hex from a file asm
Here is what I do and every time an error
project wizard --> next...16f877 --> next --> indic.location Mpaswin.exe ..---> next
creat name project file ..next --->add file asm..--> completed
after
....project open file project...---> make ------> error !!
I use MPLAB v8
after
__________________
paris (france)
Hard to help you with this we have not any thing to go by
There a lot of things that can go wrong bigest is you tried to build on the desktop
and not a C:\ myfile\firsttry.asm
I have had a 16f877 stop working and all it was is the osc stoped working. I wouldn't throw it away
it's more likely something your doing.
You building this on a solder less bread board right try two things first clip a gnd on the OSC to gnd see if that works If not remove c5 and c4 and see if that works
Alors,
I have found my issue of EP numer 265.....Sadly that issue is no longer avaiable so I cant download the source code...
Suffice to say, I built a project from another issue called Meleda, based on 16F84 that refused to work...So I wouldnt rule out a s/w issue...
This is what get's me Op ask for help with this but no code has been posted and they said they tried it with a 16f84 and no go. If you look at the circuit for 16f84 it has a 4 mhz crystal so if you left the 20mhz on the board it wouldn't work the start up delays would be to fast for the lcd.**broken link removed**
c4 and c5 removed, that does not function.
the program of this alarm ----->
Free - Envoyez vos documents
is somebody has a simple program (leds) for tested this 16f877 and knowledge s' it is good?
I specify once again that several programs were tested with this 16f877 and no n' functioned!
I can't read that maybe if you want this fix you would take time to post it so we can help you. a hex is not much good if some thing goes wrong you need the code
One do not understand .
If you look at my post since the debut, kept silent will see that it is an assembly (editing) of electronique practice ( alarm ) with one 16f877 and a quartz of 20mhz.
My probléme it is to know if my 16f877 is good....?
Bill they want a hex that blinks. yes you put the thing together so you can call it
Still need the source code not a hex I can build them and write them
It's hard to help you because we can't see what your doing and your writing is worst then mine
my lcd is good with the program of this page
test my lcd -->
Imageshack - hellw
it is necessary that I find the same program test for a 16f877. to know if the 16f877 really died
Do what Blueroom electronics suggested...flash an led....You can write the code so that you could test each pin individually or sequentially...
;*** WDT reset toggles RB0
list p=16F877A
include <p16F877A.inc>
__CONFIG 0x3F7D
org 0
bsf STATUS, RP0
movlw b'00001110'
movwf OPTION_REG
bcf TRISB, 0
bcf STATUS, RP0
movlw 1
xorwf PORTB, f
sleep
end
BRE, Hope you dont mind me posting the code...
I do not include/understand ? with which diagram ? (schématic)
thank
Follow the link....schema is at the bottom of the page...
