    Dismiss Notice
Advice for Building a Dummy Load for Amplifiers
Discussion in 'Electronic Projects Design/Ideas/Reviews' started by Bud_J, Jul 11, 2017.
  1. Bud_J
    Bud_J Member
    Aug 15, 2015
    62
    2
    Hi All,
    I've recently renewed my interest in electronics by attempting to repair an old, broken guitar amplifier I have.
    To avoid damaging the speaker, I'd like to build a dummy load for testing purposes. It's a 100W amp, though I have no intention of pushing it at full power while under test until I'm 100% sure it's fixed.
    The amp takes a 4-ohm load. I found these on eBay:
    http://www.ebay.com/itm/2-x-50W-Loa...ash=item2cb45f7fd7:g:g2sAAOSwcLxYC28o&vxp=mtr
    My thought is to put them in parallel for a 4-ohm 100W dummy load. I also like the idea of having a 50W 8-ohm load for if/when I ever work on an amp that requires an 8-ohm load.
    In looking around some of the other electronics forums, I see some people don't like the idea of using wire-wound resistors for dummy loads because they have an inductance. Others say the inductance is negligible.
    I have two questions:
    1.) Generally, what are your thoughts on using wire-wounds for dummy loads?
    2.) I'm wondering why a (somewhat) inductive load wouldn't more accurately mimic an actual speaker? After all, the speaker has a coil. So I'm wondering why some people are against using wire-wounds for dummy loads?
    All help/info appreciated. Am I over-thinking it?
    Thanks all!
    Bud
  2. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,212
    640
    Derbyshire, UK
    ONLINE
    Wirewound resistors are fine for dummy speaker loads - however, be aware that the 50W rating of those resistors requires them to be bolted to a huge and efficient heatsink, and will be hot enough to burn you.
    I made my dummy loads simply by using 1 ohm 17W resistors, wired in series parallel across tag strips - with plenty of air spacing. Then suitably downrate the wattage, as their 17W rating is also with them hot enough to seriously burn you, but at least you don't need heatsinks - you can also blow a fan across them to keep them cooler :D
  3. MikeMl
    MikeMl Well-Known Member Most Helpful Member
    Mar 17, 2009
    11,044
    541
    AZ 86334
    Another trick I sometimes use when testing DC power supplies. Stick a 4Ω 5W or 10W wire-wound resistor in a glass jar, filled with Distilled Water. As long as the resistor hasn't yet boiled away the water, it is good for ~100W.
    I have used non-inductive resistors immersed in (non-PCB) transformer oil (clean motor oil will work in a pinch) to test 1kW RF Power Amplifiers.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Bud_J
    Bud_J Member
    Aug 15, 2015
    62
    2
    Thanks, guys, all good ideas. I certainly have plenty of computer fans lying around ;-) "Large and efficient" heat sinks? Well, that's another story. I have some small and lame ones that I suppose are better than nothing for now. Will give the fan something extra to blow across.
  6. JimB
    JimB Super Moderator Most Helpful Member
    Sep 11, 2004
    6,325
    585
    Peterhead, Scotland
    ONLINE
    It has not been explicitly stated here, but wire wound resistors are no-no for radio frequency applications, ie testing radio transmitters.
    In those cases the parasitic inductance of the wire wound resistor is a real killer.
    For DC applications the wire wound resistor is fine.
    For audio frequency applications, I have no direct experience, but as others have said it should not be a problem.
  7. audioguru
    audioguru Well-Known Member Most Helpful Member
    Mar 16, 2004
    32,440
    933
    Canada, of course!
    ONLINE
    Those resistors have a power rating of only 25W on every Western distributor's website. ebay lies about everything.
  8. tomizett
    tomizett Active Member
    Aug 11, 2013
    415
    45
    UK
    Yea, wirewounds are no problem for testing at audio frequencies. As you say, loudspeakers are significantly inductive.
    Despite the fact that a speaker is nowhere near a resistive load, resistors seem to be used nearly universally in testing, even by manufacturers.
  9. dr pepper
    dr pepper Well-Known Member
    Oct 6, 2008
    4,645
    246
    North west UK
    Speaker drivers also have inductance, reactance will be 4 or 8 ohms at dc, but nothing like that at ac, theres usually one or 2 bumps around resonance then the reactance gradually rises.
    Wirewound resistors have a very small amount of inducatnce, they will not present a load like a speaker driver but ought to be good enough for most purposes, after all you just want to dump power to see if the amp is capable of doing so.
    At radio frequencies the inducance could dominate over the resistance, so for radio applications wirewound isnt good.
    • Agree Agree x 1
Share This Page
