    Dismiss Notice
Adding new transistors to LTspice???
Discussion in 'Circuit Simulation & PCB Design' started by aussiebloke, Feb 7, 2012.
  1. aussiebloke
    aussiebloke New Member
    Aug 19, 2011
    11
    0
    G'day all.
    I am wanting to build an image orthicon B&W television camera and have the complete circuit diagram for a 1960s transistorized image orthicon camera chain. Unfortunately the circuit has obsolete germanium transistors so I need to somehow substitute modern available silicon transistors in place of them and have been reading up some modification tips on substituting germaniums for silicons here http://www.hawestv.com/transistorize/germanium1.htm .
    Anyhow cutting to the chase I need to be able to test sections of the camera's circuitry using the original germanium transistors in LTspice and then with silicon transistors along with the necessary modifications test the circuitry again to see if the results match the original design. However I haven't got the faintest idea in understanding the code values of the transistors eg.:
    .MODEL 2N3393 NPN(IS=12.03E-15 ISE=8.195E-12 ISC=0 XTI=3 BF=154.1 BR=4.379 IKF=0.1072 IKR=0 XTB=1.5 VAF=37.37 VAR=12.5 VJE=0.65 VJC=0.65 RE=0.1 RC=1 RB=10 CJE=8.307E-12 CJC=5.777E-12 XCJC=0.75 FC=0.5 NF=1 NR=1 NE=1.971 NC=2 MJE=0.384 MJC=0.3199 TF=385.4E-12 TR=783.8E-12 ITF=0.17 VTF=3 XTF=8 EG=1.11 KF=1E-9 AF=1 VCEO=25 ICRATING=500M MFG=NSC)
    All of those vales make absolutely no sense to me and do not even resemble anything of that transistor's given values on alltransistors.com http://alltransistors.com/transistor.php?transistor=3141 which are:
    2N3393 Transistor Datasheet. Parameters and Characteristics.
    Material of transistor: Si
    Polarity: npn
    Maximum collector power dissipation (Pc): 200mW
    Maximum collector-base voltage (Ucb): 25V
    Maximum collector-emitter voltage (Uce): 25V
    Maximum emitter-base voltage (Ueb): 5V
    Maximum collector current (Ic max): 100mA
    Maximum junction temperature (Tj): 125°C
    Transition frequency (ft): 70MHz
    Collector capacitance (Cc), Pf: 12
    Forward current transfer ratio (hFE), min/max: 90/400
    Manufacturer of 2N3393 transistor: GEN
    Package of 2N3393 transistor: TO98-1
    Application: Low Power, General Purpose
    So I was wondering if anyone can help me on how to go about adding transistors and encoding the transistors specifications to that of LTspice's mumbo jumbo coding? Any advice would be much appreciated.
    Lastly here's the list of transistors this camera contains:
    2N337 X5 (can subsitute with 2N699 except IO safety circuit)
    2N491 X3
    2N699 X3
    2N743 X1
    2N1022 X2
    2N1131 X2
    2N1143 X12 (can substitute with 2N1301)
    2N1274 X1
    2N1308 X2
    2N1415 X2
    2N1546 X2
    2N1565 X1
    4N1908 X4
    2N1997 X9
    2N1999 X23
    2N2000 X1 (can substitute with 2N1046)
    2N2102 X2
    2N2145 X1
    2N2157A X4
    2N2671 X28 (can substitute with 2N2084 & 2N1309)
  2. ericgibbs
    ericgibbs Well-Known Member Most Helpful Member
    Jan 4, 2007
    21,233
    645
    Ex Yorks' Hants UK
    Open the following file, using a text editor and paste the model details listed below, into the
    C:\Program Files\LTC\LTspiceIV\lib\cmp\standard.bjt
    Paste it at the top of the other transistor models in that file, Save the standard.bjt file.
    Run LTspice and using F2 , select a 'npn' transistor an place the symbol on your circuit.
    Right click on the transistor symbol and then 'pick new transistor button', your NEW transistor 2N3393 should appear, select it.
    I have a asc file and image to help you test , AFTER you have added the new model.
  3. aussiebloke
    Aug 19, 2011
    11
    0
    G'day. Thanks for helping but that wasn't quite the answer I was after nor that was the question I was actually asking. That particular transistor I am aware is already in the models list in standard.bjt and I actually cut and pasted the given code for that 2N3393 transistor from standard.bjt as an example showing what kind of mumbo jumbo coded parameters LTspice uses to specify transistor values instead of having a user friendly parameter settings for us to add new transistors such the data on transistors listed on alltransistors.com .
    What I want to know is when I want to add new transistors to the standard.bjt, how do I convert the transistor specifications like max collector-base voltage, max collector current etc. to the mumbo jumbo code LTspice uses such as ISE= ISC= BF= BR= etc.? I basically want to enter all those listed old germanium transistors into standard.bjt with the appropriate codes that represent those transistors' specifications so I can accurately reconstruct sections of the camera's circuits where the transistors are in LTspice, run the appropriate signals through them and look at the output signal, then after that replace the germanium with a silicon and the appropriate resistors to make the silicon do the job similarly to the germanium and test the output signal to see if it's the same so I know if it will work or not.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. crutschow
    crutschow Well-Known Member Most Helpful Member
    Mar 14, 2008
    10,623
    479
    L.A., USA Zulu -8
    That "mumbo jumbo code" consists of standard Spice parameters used in all Spice type programs, which allows accurate simulation of the transistor operation under a wide variety of operating conditions. The parameters in a data sheet tell only enough about the transistor for the designer to use it in a circuit but not enough to accurately simulate its operation. The data sheet parameters can be converted into the spice parameters with limited accuracy. See this for a program (SpiceMod, not free) that does just that.
    So otherwise you could try to find some Spice parameters for similar germanium transistors and put them into LTSpice. The simulation won't be exact, but it should be close enough to tell you how the circuit operates. And there likely isn't that much difference between the circuit operation with germanium and with silicon, other then possibly having to adjust the base bias resistors to allow for the different Vbe.
  6. simonbramble
    simonbramble Active Member
    Nov 22, 2010
    432
    63
    SPICE parameters seem to bear no resemblance to their datasheet equivalent so you have my sympathy. Trust the mumbo jumbo and assume it is close to the datasheet performance of the part and the simulation should be accurate. Have a look at the link below for more information on importing 3rd party spice models. personally I do not import them into the standard library. If I ever have to reinstall LTSpice, I believe the standard library (hence all your models) gets deleted. I keep all the models in a separate directory
  7. crutschow
    Mar 14, 2008
    10,623
    479
    L.A., USA Zulu -8
    What I do, if I have to reinstall a program is to save all the libraries under a different name before the install. Then you can remove the new libraries and change the saved file names back to the original after the installation is complete and nothing is lost.
  8. ecosseman
    ecosseman New Member
    Jul 29, 2017
    3
    0
    I am learning LTspice XVII.
    Have placed a .model of npn MPSAO6 into /cmp.
    I can select it and place it.
    In the 'Pick New Transistor' boxes Vceo[V] and the Collector Current[A], is blank.
    Existing items have this data.
    What am I not doing?
  9. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    9,315
    1,230
    Cardiff, Wales
    Do you have Vceo and Collector Current values specified in you model statement?
  10. ecosseman
    Jul 29, 2017
    3
    0
    Thanks for reply.
    No V or I values:
    Got this model from LTwiki
    .MODEL MPSA06 npn
    IS=6.03149f BF=559.138 NF=0.841146 VAF=996.086 IKF=0.187838 ISE=1e-08
    NE=3.53096 BR=43.984 NR=0.893292 VAR=1.45264 IKR=1e-05
    ISC=3.06474e-11 NC=3.98114 RB=0.01 IRB=0.269152 RBM=0.01 RE=1e-05
    RC=0.000928752 XTB=1.17305 XTI=1 EG=1.05 CJE=5.54912e-11 VJE=0.577764
    MJE=0.313139 TF=5.4629e-10 XTF=23.7458 VTF=7.07849 ITF=4.69733
    CJC=1.76218e-11 VJC=0.4 MJC=0.285166 XCJC=0.902334 FC=0.732277
    TR=1e-07
  11. alec_t
    Jul 10, 2011
    9,315
    1,230
    Cardiff, Wales
    You can look up the Vceo and Collector Current values specified in the datasheet and paste them into the model statement, but note that LTspice will ignore these values in a simulation.
  12. ecosseman
    Jul 29, 2017
    3
    0
    Thanks for info.
    Have observed values in other .models. Have done what you said. All good.
    Cheers
Share This Page
