    Dismiss Notice
adding all digits in a number, MCU 8051
Discussion in '8051/8951' started by PG1995, Mar 31, 2012.
  1. PG1995
    PG1995 Active Member
    Apr 18, 2011
    1,645
    13
    Hi
    I want to add every digit in this number 457-85-9999-1, i.e. 4+5+7+8+.... I'm new to assembly language and using MCU 8051.
    One way to do it is given below. How else can I do it efficiently and using few lines without making it complex for myself? Please help me with it. Thank you.
    Code (text):
    ;add all digits of the number 457-85-9999-1
    ORG 0H
        Repeat:
        CLR A
        ADD A, #4
        ADD A, #5
        ADD A, #7
        ADD A, #8
        ADD A, #5
        ADD A, #9
        ADD A, #9
        ADD A, #9
        ADD A, #9
        ADD A, #1
        SJMP Repeat
    END
    Regards
    PG
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,170
    910
    Rochdale UK
  3. Jon Wilder
    Jon Wilder Active Member
    Oct 22, 2010
    859
    82
    Fresno, CA
    A really good site I recommend to anyone wishing to learn the MCS-51 family is http://www.8052.com
    This site was what got me started with the MCS-51 family. I started embedded electronics and assembly language programming with the 16F series of PIC microcontrollers a year and a half ago (knowing nothing about digital electronics or any sort of programming), then took on learning the MCS-51 family last summer. I just finished up writing my first MCS-51 code that I started back in February and it's working 100% bug free now.
    Despite the haters who hate on it for no other reason than its age, the MCS-51 family is a very fun family to code in assembly. I enjoy coding it over the PIC to be honest. But I use both processors in different types of applications, with my favorite PIC being the 16F88/F886/F887. For MCS-51 stuff I use Atmel's AT89S series and am currently working with the AT89S8253.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    You can also preload these values into RAM registers, then set up a loop that adds them via indirect addressing. With indirect addressing you can set the add loop as a subroutine, then change the values loaded in the registers in main code, init the counter and call the subroutine to add any combination of digits, making the whole thing configurable in main code -
    Code (text):
    DigitLoad:  mov     0x30,#4         ;load digits into RAM
            mov     0x31,#5
            mov     0x32,#7
            mov     0x33,#8
            mov     0x34,#5
            mov     0x35,#9
            mov     0x36,#9
            mov     0x37,#9
            mov     0x38,#9
            mov     0x39,#1
            mov     R1,#0x0A        ;set counter for 10 digits
            acall       AddDigit
            ;continue with main code
    AddDigit:   push        ACC         ;store accumulator
            push        R0          ;store R0
            mov     R0,#0x30        ;set starting RAM address
            mov     A,#0            ;clear accumulator
    AddLoop:    add     A,@R0           ;add digit
            inc     R0          ;increment digit address
            djnz        R1,AddLoop      ;decrement digit counter, continue adding if counter > 0
            pop     R0          ;restore R0
            pop     ACC         ;restore accumulator
            ret
    When using this method, make sure you load the first digit into RAM location 0x30, then follow them with each digit in sequence as shown above.
    Notice I also use the stack to my advantage to back up the registers that will be used in the subroutine, then restore them on subroutine exit. This is a very good programming habit to get into.
  6. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    Jon.. In my hayday, I went to Portsmouth University to visit Frederick Cowan, David Callcot and Hassan Parchizadeh the three authors of "8051 Microcontrollers"
    I spent a great day with them discussing the book... I came away with oodles of goodies... SBC's, Development kits and tons of literature. I was a tiny bit responsible for the second edition.. Hassan, whom wrote the C portions of the book, had minor mistakes and we sat down and corrected the parts that needed correcting. I treated them to a dinner. This was my first experience of 3D printing as they had one of the first.. It printed wax or wood.. The wood was liquid and came out with a kind of veneer finish.
    I totally love it... Right in the heart of phillips development.... (Portsmouth was an excellence center for Phillip's micro's)
  7. PG1995
    Apr 18, 2011
    1,645
    13
    Thank you very much, once again, Rogers, Jon. You guys are really helpful and nice too!
    Just wanted to confirm: I don't think assembly language for 8051 is case sensitive, is it? Is it true of every other assembly language? Please let me know.
    @Rogers: You were right about MCU 8051 IDE. It is a great simple tool for beginners like me. Though I have Keil installed too but I like it more. Thanks for the recommendation.
    Best wishes
    PG
  8. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    The labels you use are case sensitive yes. I think the built in assembler in MCU8051IDE is a bit forgiving with that.
    I always tend to type instructions in lower case and constant labels in upper case. For line labels and subroutine names I capitalize the first letter of every word. That's just my personal naming convention.
  9. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    PG.. I use asem51 with protues aswell.... There are many options for these little devices... If you download VSM studio (if you have proteus) you can debug with ISIS....
  10. PG1995
    Apr 18, 2011
    1,645
    13
    Thank you, Jon, Rogers.
    @Rogers: I have Proteus ISIS installed along with Keil uVision and MCU 8051 IDE. I have also downloaded VSM Studio but I think I would stick with MCU 8051 IDE because as a beginner it seems simple to me. But thanks for telling me about the VSM.
    Best regards
    PG
  11. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    I must admit... Its very good!! The more I play with it, the more it seems to do..... If you ever start messing with C.. You can add the compilers directly to it.
    Have fun.
  12. PG1995
    Apr 18, 2011
    1,645
    13
    Hi
    Could you please help me with interfacing LCD display in MCU 8051 IDE?
    First I need to change the code below so that "AMERICA" is sent to port 0 which is connected to a LCD.
    Please help me. Thanks.
    Regards
    PG
    Code (text):
    ORG 0000
                MOV     DPTR,#MYDATA
            MOV     R0,#40H
            MOV     R2,#7
      BACK: CLR     A
             MOVC   A,@A+DPTR
            MOV @R0,A
            INC DPTR
            INC R0
            DJNZ    R2,BACK
      HERE:     SJMP    HERE
            ORG     250H
      MYDATA:   DB  "AMERICA"
            END
  13. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    Code (text):
    ; Lcd 16x2 display
    ;P3.2 = RS... P3.3 = R/W... P3.4 = E
        org 0
        sjmp    Start
        org 20h
    Start:
        clr P3.3
        mov a.#38h      ; function set 8 bits 2 rows 5x7 font
        acall   lcd_cmd
        mov a.#0Eh      ; screen on..cursor on.. no blink
        acall   lcd_cmd
        mov a.#06h      ; R/L cursor
        acall   lcd_cmd
        mov a.#01h      ; clear and home
        acall   lcd_cmd
        mov DPTR, #msg  ; point at message
        acall   lcd_print   ; send it to display
    fin:
        sjmp    fin
    lcd_print:
        mov a,#0h       ; start of msg
        movc    a,@a+DPTR   ; set data pointer
        cjne    a,#0h, mod1 ; wait for null
        ret
    mod1:
        acall   lcd_data    ; send char to screen
        inc DPTR        ; get next char
        sjmp    lcd_print   ; again
    msg1:
        db  "AMERICA",0 ; message
    lcd_data
        mov P1,#0FFh    ; make input
        setb    P3.3        ; R/W = Read
        clr P3.2        ; RS = command
    waitd:
        clr P3.4        ; E low
        setb    P3.4        ; E high
        jb  P1.7,waitd  ; get busy flag
        clr P3.4        ; E low
        clr P3.3        ; R/W write
        setb    P3.2        ; RS data
        mov P1,a        ; put data on LCD port
        setb    P3.4        ; E high
        clr P3.4        ; E low
        ret
    lcd_cmd
    waitc:
        clr P3.4        ; E low
        setb    P3.4        ; E high
        jb  P1.7,waitc
        clr P3.4        ; E low
        clr P3.2        ; RS command
        mov P1,a        ; put command on LCD port
        setb    P3.4        ; E high
        clr P3.4        ; E low
        ret
        end
    This is a simple program to write to port 1 (8 bit ) with control on port 3 its easy to change ports..
  14. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    Can you tell us the make and model of the exact display you're using? Please help me help you. Thanks. ;)
  15. PG1995
    Apr 18, 2011
    1,645
    13
    Hi Jon
    I'm using this software, MCU IDE 8051, recommended by Rogers. Though, I also have Keil uVision. It was a virtual, probably generic, LCD. Please see the attachments. I don't think I would be able to interface it because what Rogers posted in the last post just was over my head!
    Regards
    PG
  16. Jon Wilder
    Oct 22, 2010
    859
    82
    Fresno, CA
    The LCD has an 8 bit data port. This data port has pins DB0-DB7. You pick a port on the MCU to drive this 8 bit data port with and the MCU's port pins will connect to their corresponding pins on the LCD data port.
    Example, let's say you decide to use Port 1 on the MCU for the LCD data port. You would connect lines DB0-DB7 on the LCD module to Port 1 on the MCU as follows -
    DB0 - MCU Port 1 Bit 0 (P1.0)
    DB1 - MCU Port 1 Bit 1 (P1.1)
    DB2 - MCU Port 1 Bit 2 (P1.2)
    DB3 - MCU Port 1 Bit 3 (P1.3)
    DB4 - MCU Port 1 Bit 4 (P1.4)
    DB5 - MCU Port 1 Bit 5 (P1.5)
    DB6 - MCU Port 1 Bit 6 (P1.6)
    DB7 - MCU Port 1 Bit 7 (P1.7)
    Then you would decide what port lines on either ports 2, 3 or 4 to use for driving the E (Enable), RS (Register Select) and R/W (Read/Write) lines on the LCD module. To send data to the LCD, you would write the data to register P1 on the MCU and set the RS, R/W and E lines accordingly.
  17. PG1995
    Apr 18, 2011
    1,645
    13
    Thank you, Jon.
    Though Rogers gave me the code in his last post, I wasn't able to understand it as I pointed out in my last posting. Forget about the LCD interfacing. Could you please help me to edit this code in a way that the word AMERICA is sent to the port 1? I think sending the complete word at one time would make things difficult so it sends one letter of word AMERICA to port 1 at a time with a delay of 200ms between sending each letter and a delay of 400ms between start of each sending cycle. This is what I'm trying to say. At first letter "A" is sent to port 1, then there is a delay of 200ms, then "M" is sent,..., now "C" is sent, 200ms delay, and now at last last "A" is sent. One cycle of sending the word is complete. Now there is a delay of 400ms and after that cycle restarts.
    Code (text):
    ORG 0000
                MOV     DPTR,#MYDATA
            MOV     R0,#40H
            MOV     R2,#7
      BACK: CLR     A
             MOVC   A,@A+DPTR
            MOV @R0,A
            INC DPTR
            INC R0
            DJNZ    R2,BACK
      HERE:     SJMP    HERE
            ORG     250H
            END
  18. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    That's is what all lcd code does.... Notice the routine in the code I posted
    lcd_print It is very similar to your original code... It has the msg pointer placed in the DPTR.. and fetches one byte at a time
    Code (text):
    lcd_print:
        ret
    mod1:
    You need to open the lcd port only when the command bits are correct.. This is why we write lcd_data and lcd_cmd routines
    All these routines do is wait for the module to be ready!!! then place the data or command on P1...
    You can't just put data on P0 or P1 without controlling the LCD module... The module has its own processor on board (even virtual ones)
  19. PG1995
    Apr 18, 2011
    1,645
    13
    Thank you, Rogers.
    I have tried to assemble the quoted code above in MCU 8051 IDE and several errors were repoted. Could you make any sense out them? Thank you for the help.
    Code (text):
    Compiling file: rogersLCD.asm
    Initializing pre-processor ...
    Syntax error at 11 in rogersLCD.asm: Too few operands, mov must take exactly 2 operands
    Syntax error at 13 in rogersLCD.asm: Too few operands, mov must take exactly 2 operands
    Syntax error at 15 in rogersLCD.asm: Too few operands, mov must take exactly 2 operands
    Syntax error at 17 in rogersLCD.asm: Too few operands, mov must take exactly 2 operands
    Syntax error at 12 in rogersLCD.asm: Symbol not defined: lcd_cmd
    Syntax error at 14 in rogersLCD.asm: Symbol not defined: lcd_cmd
    Syntax error at 16 in rogersLCD.asm: Symbol not defined: lcd_cmd
    Syntax error at 18 in rogersLCD.asm: Symbol not defined: lcd_cmd
    Syntax error at 20 in rogersLCD.asm: Symbol not defined: msg
    Syntax error at 32 in rogersLCD.asm: Symbol not defined: lcd_data
    Syntax error at 37 in rogersLCD.asm: Invalid expression: `"AMERICA"'
    Syntax error at 39 in rogersLCD.asm: Unknown keyword: `lcd_data'
        `lcd_data' is neither macro nor instruction nor directive
    Syntax error at 55 in rogersLCD.asm: Unknown keyword: `lcd_cmd'
        `lcd_cmd' is neither macro nor instruction nor directive
    Pre-processing FAILED !
    Creating code listing file ...      -> "rogersLCD.lst"
    13 errors, 0 warnings
  20. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    Sorry mate..... I did copy it over quickly
    Code (text):
    ; Lcd 16x2 display
        org 0
        sjmp    Start
        org 20h
    Start:
        clr P3.3
        mov a,#38h      ; function set 8 bits 2 rows 5x7 font
        acall   lcd_cmd
        mov a,#0Eh      ; screen on..cursor on.. no blink
        acall   lcd_cmd
        mov a,#06h      ; R/L cursor
        acall   lcd_cmd
        mov a,#01h      ; clear and home
        acall   lcd_cmd
        mov DPTR, #msg1 ; point at message
    fin:
        sjmp    fin
    lcd_print:
        ret
    mod1:
    msg1:
        db  'AMERICA',0 ; message
    lcd_data:
    waitd:
        clr P3.4        ; E low
        setb    P3.4        ; E high
        clr P3.4        ; E low
        setb    P3.2        ; RS data
        setb    P3.4        ; E high
        clr P3.4        ; E low
        ret
    lcd_cmd:
    waitc:
        clr P3.4        ; E low
        setb    P3.4        ; E high
        jb  P1.7,waitc
        clr P3.4        ; E low
        setb    P3.4        ; E high
        clr P3.4        ; E low
        ret
        end
    'll need to look into the "AMERICA" error... It seems fine....Ah single quotes not double...
  21. Ian Rogers
    Mar 28, 2011
    9,170
    910
    Rochdale UK
    I've tested this in the real world and it works ok...But it wont work on the simulator.... It wont read the busy flag... You may want to put a delay in instead of polling the busy...
Share This Page
