    Dismiss Notice
Add USB to any PIC project for less then $3
Discussion in 'Microcontrollers' started by Mike - K8LH, Feb 28, 2010.
  1. DirtyLude
    DirtyLude Well-Known Member
    Aug 5, 2003
    1,904
    56
    Toronto, Canada
    Noticed this crystal is a suggested crystal in the MCP2200 datasheet. .42 in singles at Mouser and has built in capacitance, so no external caps needed.
    CSTCE12M0G55-R0 Murata Resonators
  2. AtomSoft
    AtomSoft Well-Known Member
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Why wont it work in Parallel? a 18pf and 10pf heh
    Capacitors in Parallel
    Im no pro but thats what i would do ...
  3. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Nice work Mark!!! i just added it to my basket heh. I love SMT then you had to go and make it be a Resonator type ... man its a all in one solution...
    Thanks again. I probably would have been using a Cap and Crystal forever heh
    Also it says the capacitance can be 30/33/39pF
    so 39pf can be used?
    In the datasheet for MCP2200 they have a example of:
    http://www.mouser.com/ProductDetail/Murata/CSTCE12M0G15L99-R0/?qs=8wOOb4nECAtGxVWl3FcxzQ==
    Also
    http://www.electro-tech-online.com/custompdfs/2010/12/51901A.pdf
    Page 19 ; x1 = CSTCE12M0G15L99-R0
    So heh there the same brand too
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Mosaic
    Mosaic Well-Known Member
    Jun 3, 2010
    2,568
    128
    Caribbean
    Hmm, resonators are not noted for their accuracy...here's a .1% version...same price
    http://www.newark.com/avx/pbrc-12-00hr/ceramic-resonator-12mhz-smd/dp/96M0954
  6. mvs sarma
    mvs sarma Well-Known Member
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    I feel that two numbers of 22pF, one on each side, are enough. and no need to be too specific .
  7. be80be
    be80be Well-Known Member
    Aug 23, 2008
    4,791
    134
    morristown,tn
  8. Mosaic
    Jun 3, 2010
    2,568
    128
    Caribbean
    looks good!!
  9. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    yeah,. i hesitated at first since its a exe and from a site called "hackinglab" heh makes you think a bit.... but then i thought heh its Burt... hes legit! :)
  10. be80be
    Aug 23, 2008
    4,791
    134
    morristown,tn
    It's a good program You can even program chips with it. The old school way
  11. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Looks full featured heh like i can do anything needed with it heh... ill test it right now
    Ah... cant select custom PORT :( my MCP2200 is on COM8... ill have to change it heh
  12. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Nice here is a small token of data from my Accelerometer UART... i have it set at 4800bps... (for now)
    Code (text):
    Terminal log file
    Date: 12/26/2010 - 8:24:15 PM
    00 00 00 58 00 00 02 00 00 00 58 00 00 02 00 00
    00 58 00 00 02 01 00 01 58 00 00 02 00 00 00 58
    00 00 01 00 00 00 58 00 00 02 00 00 00 58 00 00
    02 00 00 00 58 00 00 02 00 00 00 58 00 00 02 00
    00 00 58 00 00 02 00 00 00 58 00 00 02 00 00 00
    58 00 00 02 00 00 00 58 00 00 02 00 00 00 58 00
    00 02 00 00 00 58 00 00 02 00 00 00 58 00 00 02
    00 58 00 00 02 00 00 00 58 00 00 02 00 00 00 58
    00 00 02 00 00 00 58 00 00 02 00 00 00 58 00 00
    02 00 00 00 58 00 00 02 01 00 01 58 00 00 02 00
    58 = 0x58 which is the signal to collect the next 6 bytes of data which is, Xn,XH,XL,Yn,YH,YL
    Xn is a flag to signify X is NEGATIVE
    XH is the upper byte of int X
    XL is the lower byte of int X
    Y is the same as X but well... Y :)
    So " 58 00 00 02 01 00 01" would be Start, X=+2,Y=-1
    Simple heh
    This all falls into this USB post since its from the MCP2200... I miss my FTDI but too expensive... I like it more because i dont have to worry about crystal/resonator heh. But price matters a ton these days.
  13. be80be
    Aug 23, 2008
    4,791
    134
    morristown,tn
    You can alias com ports but that a book in it self Google aliasing serial com ports for windows xp you'll see what I mean
    And when you get into Linux you get real power over Com ports
  14. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    Yeah i get it heh... Yet another reason to play with Linux... heh
  15. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    On the topic of linux and usb and PIC you think it would be harder or easier to write straight USB code for LINUX?
  16. be80be
    Aug 23, 2008
    4,791
    134
    morristown,tn
    Linux has a lot out there as way of code that you could learn by and reuse. I think as good as you are at C you'll be more at home with Linux
  17. AtomSoft
    Feb 7, 2008
    5,670
    41
    Brooklyn, NY US
    heh thanks for the complement. Im learning as i go.
    Slight off topic right here... i play lotto now almost everyday... hoping to win big... if i do i plan on buying a little set of things and hosting a contest here on the forums. Maybe like $500 worth of stuff... like sensors, buttons and a whole starter kit to making PCBs (including a printer)....
    So do me a favor and wish me luck guys... if i get it ill host something ... and some people will win.. (of course there will be 2nd and 3rd prizes) :D
    ok back on topic... I am going to setup a PC i have on the side with Linux and see how it goes. I hear Ubuntu is like all the rage in the linux world heh
  18. mvs sarma
    Oct 29, 2006
    3,512
    76
    Hyderabad, India.
    All the best of success in your learning Atomsoft !!
Share This Page
