    Dismiss Notice
ADC not working | ATMEGA16A | C++ AVRStudio
Discussion in 'AVR' started by ikelectro, Oct 24, 2015.
  1. ikelectro
    ikelectro Member
    Aug 25, 2012
    388
    4
    Kolkata, Proud to be an Indian.
    Here is the code below. the code does not working with my hardware but with the same hardware ASM code is working. The result always same in C++.
    Code (text):
    #define F_CPU 4000000UL
    #include <avr/io.h>
    #include <util/delay.h>
    #include <string.h>
    int main(void)
    {   DDRB = 0xFF;            //PORTB AS OUT PUT
        DDRA =0;                //PORTA AS INPUT OF ADC
        ADCSRA = 0x87;        //initiazing ADC
        ADMUX = 0xC0;
        _delay_ms(2000);    //delay for 2seconds
        while(1)
        ADCSRA |=1<<ADSC;
        while (( ADCSRA&(1<<ADIF))==0);
        int z = ADCL;
        _delay_ms(20);        //delay for 20mili seconds
        int x = z%10;
        PORTB = 12;
        _delay_ms(1000);
        PORTB = x;            //3rd digit
        _delay_ms(1000);
        int a=z/10;
         unsigned short int b=a%10;
        PORTB = 13;
        _delay_ms(1000);
        PORTB = b;            //2nd digit
        _delay_ms(1000);
    unsigned short int c =a/10;
        PORTB =14;
        _delay_ms(1000);
        PORTB = c;            //1st digit
        _delay_ms(15000);
          return 0;
  2. ikelectro
    ikelectro Member
    Aug 25, 2012
    388
    4
    any one????? please help me out.
  3. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,151
    907
    Rochdale UK
    ONLINE
    I would help, but I'm not that familiar with AVR... What isn't working .. Nothing on portb??? Wrong data on portb??
    Where are your fuse settings?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. misterT
    misterT Well-Known Member Most Helpful Member
    Apr 19, 2010
    2,697
    368
    Finland
    I think you may have the same problem as in this thread: http://www.electro-tech-online.com/...c-register-because-it-has-been-locked.141734/
    Short answer is that you also need to read the "high byte" register ADCH after reading the low byte ADCL. Even if you don't use the high-byte, you need to read it.
    Just read it to a dummy variable after:
    int z = ADCL;
    int adc_high = ADCH;
  6. ikelectro
    ikelectro Member
    Aug 25, 2012
    388
    4
    okay, I'll give it try after returning home. Thanks for your reply.
Share This Page
