    Dismiss Notice
A routine to limit range of 16bit variable
Discussion in 'Code Repository' started by Lourens, Jun 3, 2012.
  1. Lourens
    Lourens Member
    Apr 30, 2010
    102
    4
    Roodepoort, South Africa
    I am sure there are many more interesting pieces of code out there.... This one is for PIC18's to limit 16bit signed variables to a spesific range. Note that if the least significant byte is located at n then the most significant is at n+1.
  2. secretagent
    secretagent New Member
    Mar 20, 2012
    69
    0
    Mission, CA
    Code (text):
    if(var>567){var=567;}
    This will make sure var is never over 567. If you want it never over 567 and never under 235
    Code (text):
    if(var<235){var=235;}
    Is this what you were looking for?
    I am not sure what it is exactly in asm but if you know C this may help you :)
  3. Lourens
    Lourens Member
    Apr 30, 2010
    102
    4
    Hi secretagent, i was not particularly looking for ways to limit a variable, this was rather aimed at the (older like me?) assembler users that require a fast way to limit a variable to a particular range, which was the case in my pid routine . Thanks for the comment.
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. WTP Pepper
    WTP Pepper Active Member
    Jan 24, 2012
    648
    41
    UK
    Old thread I know, but if you can choose your range sensibly like between 512 & 256 then in assembler language it's just a case of clearing (in this case) all bits above bit 9
  6. Lourens
    Lourens Member
    Apr 30, 2010
    102
    4
    Hi WTP, you are correct. In many a case i want to make full use of the 16 bits because of accuracy (and when using fixed point). Some values (can be + or - ) in a calculation can however upset things if they are out of a particular range. This routine is then handy to keep things within limits.
    Glad there are still some assembler programmers out there!
Share This Page
