    Dismiss Notice
__config problem
Discussion in 'Microcontrollers' started by Savlon, Apr 7, 2004.
  1. Savlon
    Savlon New Member
    Feb 10, 2004
    15
    0
    Manchester, England
    Hi, could anyone please tell me where i am going wrong. I am trying to program a PIC16F737 to have an internal 8MHz clock, when i use the config command i get an error saying "ERROR[126] Argument out of range (not a valid config register address)" when i build. The code is:
    Code (text):
    __config 0x3790
    I have tried using the binary value too (b'11011110010000') but get the same error. Has anybody ever had this problem? I tried using the configuration bits window, however when i began to program the chip a warning comes up saying that the configuration settings have not been updated, proceed with previous configuration, can anybody tell me how to update these settings?
    Thanks!
  2. motion
    motion New Member
    Jul 14, 2003
    560
    0
    Quezon City.PH
    This is taken from the file "PICF16F737.INC"
    Code (text):
    ; To use the Configuration Bits, place the following lines in your source code
    ;  in the following format, and change the configuration value to the desired
    ;  setting (such as CP_OFF to CP_ALL).  These are currently commented out here
    ;  and each __CONFIG line should have the preceding semicolon removed when
    ;  pasted into your source code.
    ;Program Configuration Register 1
    ;       __CONFIG    _CONFIG1, _CP_OFF & _CCP2_RC1 & _DEBUG_OFF & _VBOR_2_0 & _BOREN_1 & MCLR_OFF & _PWRTE_OFF & _WDT_OFF & _HS_OSC
    ;Program Configuration Register 2
    ;       __CONFIG    _CONFIG2, _BORSEN_1 & _IESO_OFF & _FCMEN_OFF
    The __CONFIG pseudo op can only take 8-bit operands and so two are needed. Also, avoid using "magic numbers". Use the labels supplied by Microchip.
  3. johnson
    johnson New Member
    Apr 5, 2004
    9
    0
    how about Pic Basic? I have the same problem in implementing _config ......
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Savlon
    Savlon New Member
    Feb 10, 2004
    15
    0
    Manchester, England
    Got the oscillator working now, thanks very much!!
Share This Page
