8051 simple counter
Jon1997
Hi I am currently using an AT89S52 and I am looking for a code (for keil uVision3) that does the following:
- reads my input voltage
- it must count up each time voltage is 3
- display the count in 4-bit binary on 4 led
What is your sensor? How is the signal "weak"? Do you realize that an 8051 is not an amplifier so you will most likely have to use some sort of external signal conditioning to bring the signal to a level the 8051 can register.
I would appreciate it if some one can provide a code or hex file to program my AT89s52.
I would like the chip to function as an up counter and have an output display in 4-bit binary code on 4 led.
Do you expect the Atmel to compare for the 3V or do you have an external comparator?
In case you have a comparator, connect it to port P3.2, configure that pin edge sensitive and in the ISR write something like
inc  MyCounter
reti
First you talked LCD now 4 led's? What will it be??
In case of four led's
you need some code like
mov P1,MyCounter
In case of LCD
That will be a lot more code
I wrote a LCD library with subroutines to initialize the LCD, write text and data on the LCD, create user defined characters, ... ...
Search my posts and you may find it :)
thak you mcs51mc
I understand i must increment my count, but how do I make it inc each time input has changed?
is this correct?
MOV TMOD,#01100000B ;mode 2, counter 1
MOV TH1,#0
SETB P3.5 ;make T1 input port
AGAIN:SETB TR1 ;start
BACK: MOV A,TL1
MOV P2,A ;display in P2
JNB TF1,Back ;overflow
CLR TR1 ;stop
CLR TF1 ;make TF=0
SJMP AGAIN ;keep doing it
If you have a comparator to check the 3V then use pin P3.2 setup as edge sensitive. Each time the pin goes low, the ISR for that pin is triggered.
CSEG AT RESET
	jmp MainProg            ;Main loop
CSEG AT EXTI0
        jmp intP32		;ISR for P3.2
;ISR for pin P3.2
			RSEG intP32
			inc  MyCounter
			reti
;Main loop
			RSEG MainProg
                	mov  sp,#Stack-1		;initialize stack
			mov  R0,#0FFh			;clear internal RAM
			clr  a
LBL_ClearRAM:		mov  @R0,a
			djnz R0,LBL_ClearRAM
			setb IT0			;Interrupt P3.2 edge sensitive
			setb EX0			;Enable interrupt pin INT0 P3.2
			setb EA    			;Enable all interrupts
LBL_Loop:		mov  P2,MyCounter		;Value to port 2
			jmp  LBL_Loop
The instructions setb IT0 and setb EX0 makes from P3.2 an edge sensitive input pin.
If you don't have a comparator you need an ADC to digitalize the signal from your sensor and read it in the µP.
Check the attached app note for the AD22100 temperature sensor from Analog Devices. They do what you want to do but with another sensor...
  • AD22100_AN-395.pdf
