    Dismiss Notice
8051 assembly code for counter
Discussion in '8051/8951' started by Parth86, Nov 22, 2013.
  1. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    I want make counter program for 8051 controller in assembly that count 0 to 9 I know I have to use counter, timer, interrupt routine , instruction set ( mov, add INC DEC....) now problem is that I have no idea how to start please anyone will help me to write code
  2. Ian Rogers
    Ian Rogers Super Moderator Most Helpful Member
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    I thought I gave you a bit of code in your other thread.... What do you need?
  3. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    no that are in c language i need in assembly language
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    Right O... I'll be at home in about an hour...
    I'll put a skeletal ASM program together ( actually I already have one ) and post it soon..
  6. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    ok can you tell me what is the use of register bank and SFR in ram i think register bank is used to store location of data
    and don't know about SFR
  7. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    I'll try and explain later... SFR's are at the top of the ram banks 0x80 and up...
  8. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    ok I will wait for your reply
  9. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    I just put this together
    Its a start at least..
    Code (asm):
    RS     BIT P3.1        ; LCD
    RW     BIT P3.2        ; Constants
    E     BIT P3.0        ;
    BZ    BIT P1.7        ; busy flag
        org     0h        ; reset vector
        sjmp    Start
        org    20h        ; jump over vectors
    ; Start of code
    Start:
        acall    LcdInit        ; called once only
    While:
        acall    LcdLine1    ; Goto Line1
        mov     DPTR,#MSG1
        acall    LcdPrint    ; Display message
        acall    LcdLine2    ; goto Line2
        mov     DPTR,#MSG2    ;
        sjmp    While        ; forever loop
    MSG1:
        db    "First Line ",0
    MSG2:
        db    "Second Line ",0
    ; Initialize LCD
    LcdInit:
        clr    RW
        acall    delay40Ms
        mov    P1,#33h        ; Init once
        setb    E
        clr    E
        acall    delayMs        ; Init twice
        setb    E
        clr    E
        acall    delayMs        ; Now busy can be read.
        mov    a,#38h        ; Function set: 8 bits: 2 Line : font 5x7.
        acall    LcdCom
        mov    a,#0Ch        ; Display On: Cursor Off : Blink Off.
        acall    LcdCom
        mov    a,#06h        ; Shift forward.
        acall    LcdCom
        mov    a,#01h        ; Clear Goto position 1.
        acall    LcdCom
        ret
    ; Goto first line
    LcdLine1:
        mov    A,#80h        ; position 1 on line 1
        acall    LcdCom
        ret
    ; Goto second line
    LcdLine2:
        mov    A,#0C0h        ; position 1 on line 2
        acall    LcdCom
        ret
    ; Print a null terminated string
    LcdPrint:
        mov    A,#0h
        movc    A,@A+DPTR    ; Through string until 0
        cjne    A,#0,Char    ;
        ret
    Char:
        acall    LcdData        ; Print data character
        inc    dptr
        sjmp    LcdPrint
    ; Waiting for LCD module
    LcdBusy:
        mov    P1,#0FFh    ; tristate the port
        clr    RS        ; command mode
        setb    RW        ; Read flags
    busy:    clr    E
        setb    E
        nop
        jb    BZ, busy    ; wait until ready
        clr    E
        clr    RW        ; Back to write mode
        ret
    ; Send command to LCD module
    LcdCom:                ; sends a command
        acall    LcdBusy
        clr    RW
        clr    RS
        mov    P1,A        ; Acc has command
        setb    E
        clr    E
        ret
    ; Send data to LCD module
    LcdData:            ; Sends data
        acall    LcdBusy
        clr    RW
        setb    RS
        mov    P1,A        ; Acc has data
        setb    E
        clr    E
        ret
    ; Delays
    delay40Ms:
        mov    R1,#25h        ; Simple delay @ 40 milli seconds
    dlyM:    acall    delayMs
        djnz    R1,dlyM
        ret
    delayMs:
        mov    R0,#0h        ; Simple delay @ 1.1 milli second
    dlyU:    nop
        nop
        djnz    R0,dlyU
        ret
        end
    [code]
    We'll do some interrupts later..
  10. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
  11. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    hello ion, this code is very difficult to understand me where you used interrupt subroutine where is timer mode i have read to write counter program we need interrupt timer mode
  12. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    I said we'll do that later... I need you to understand the code for the LCD first..
    As we introduce interrupts I can explain the timer and the external count!
    Which assembler do you want to use... I would recommend ASEM51...
    I have purposely used the INT pins so you can see what happens when you design systems... You can have a PCB made, then find out you need to use alternate pins for something else...
    I will show you an interrupt routine first.... Then I will see if you can integrate the two
    Code (asm):
    countl    equ    20h
    counth    equ    21h
        sjmp    Start
        org    03h        ; Ex0 interrupt
        sjmp    ISR
    ; Start of code
    Start:
        setb    P3.2        ; INT0 as input
        setb    IT0        ; Set level of interrupt
        mov    IE,#081h    ; Global On : INT0 On..
    While:
    ISR:
        mov    A,countl    ; get counter low byte
        mov    B,counth    ; get counter high byte
        add    A,#1        ; increase counter low
        jnc    non        ; are we at 255
        inc    b        ; yes! increase Counter high
    non:    mov    countl,A    ; store Low
        mov    counth,B    ; store High
        clr    IE0        ; ensure flag off.
        reti            ; return from interrupt..
        end
    Tell me if you understand this.... If not I'll go through it with you..
  13. Parth86
    Parth86 Member
    Dec 25, 2011
    510
    5
    first thanks for help' can you explain with theory I want to understand some basic things that is used in every counter program I want to understand what basic instruction I need to use to create every counter program in theory I have read loading data transfer arithmetic logic instruction I know how to make loop, labels directives I want to create some basic algorithm for counter program for begainer
  14. Ian Rogers
    Mar 28, 2011
    9,141
    907
    Rochdale UK
    ONLINE
    Well just look at the code I posted..
    The counter is incremented on the high to low transition on P3.2 (INT0) pin.
    If the countl variable overflows, the counth variable is incremented, thus giving a 16 bit counter.
    Next we need a BCD routine to be able to print the count to a screen..
    You can also use a built in timer as a counter... If you just want to count with a register then the simplest command is inc A This just increases Acc by one...
  15. remon7
    remon7 Active Member
    Aug 3, 2013
    122
    55
    Malaysia
    As Far as I know,
    .MODEL SMALL
    .STACK 100H
    .DATA
    PROMPT DB 'The counting from 0 to 9 is : $'
    .CODE
    MAIN PROC
    MOV AX, @DATA
    MOV DS, AX
    LEA DX, PROMPT
    MOV AH, 9
    INT 21H
    MOV CX, 10
    MOV AH, 2
    MOV DL, 48
    loop:
    INT 21H
    INC DL
    DEC CX
    JNZ loop
    MOV AH, 4CH
    INT 21H
    MAIN ENDP
    END MAI
Share This Page
