8051 ascending order
4electros
I need to ask about the mechanism of generating ascending number code,the numbers are taken from a block starting from address 30h and its length stored in address 31h.it's required to put those numbers in ascending order in a block of numbers starting (for example) from address 60h.
any clue will be appreciated.
You are refering to a sorting algorithm. The two which might be applicable in your case are the Bubble Sort and the Insertion Sort. Google them and get millions of hits
4electros said:
what did you mean exactly by sorting and algorithm,i thought that they are the same
One is a verb the other is a noun. Adding the -ing ending to a verb makes it a modifier of the noun.
sort (vt.) arrange a collection of objects according to an ordering rule (eg. ascending or descending)
algorithm (n.) a sequence of steps which lead to a desired result.
A sorting algorithm is different from a random number generating algorithm.
