555 Beginner problem
NLT
Hi
I have this assignment, and I have absolutely no idea what I’m doing.
I need to design a circuit that produces the output as attached.
T1=1ms
Duty Cycle1 = 0.75
Duty Cycle2=0.75
T2 can be calculated from T1
tpw3 can be calculated from T2
I have to use monostable and astable multivabrators.
It seems there are 3 circuits that need to be interconnected.
I have the following:
2 (possibly 3) 555 timers.
A variety of caps.
A variety of resistors.
Can anyone please help!? Assume I know nothing.
I’m supposed to simulate in LTspice. If you could provide a schematic, and explain what it does, that would be awesome!
Thank you very much!
Have you downloaded and read the 555 data sheet?
  • Like
Reactions: NLT
OK. So, this is my attempt. It doesn’t work.
From left to right:
Monostable for pulse 3 - > Astable for pulse 2 -> Astable for pulse 1.
Calcs:
For pulse 1:
f= 1/T = 1/1m = 1k
Choose
C3=100n
R4=3.6k
R5=7.2k
Then f= 1.44/((R5+2*R4)*C3)
= 1.44/((7.2k+2*3.6k)*100n)
=1k as required
Duty cycle = (R5+R4)/(R5+2*R4)
=(7.2k+3.6k)/(7.2k+2*3.6k)
=0.75 as required
For pulse 2:
I reasoned that (I don’t know if this is right) the up time for pulse 2 is equal to (trailing edge of last cycle of pulse 1) – (leading edge of first cycle of pulse 1)
=4*1m+1m*0.75
=4.75m
Then the period is
T=4.75m/0.75=6.33m
Then f= 1/6.33m
=0.158k
Choose
C2=100n
R2=22.8k
R1=45.6k
Then
f= 1.44/((R1+2*R2)*C3)
= 1.44/((45.6k+2*22.8k)*100n)
= 0.158k as required
Duty cycle = (R1+R2)/(R1+2*R2)
=(45.6k+22.8k)/(45.6k+2*22.8k)
=0.75 as required
For pulse 3:
I reasoned that (I don’t know if this is right) the up time for pulse 3 is equal to (trailing edge of last cycle of pulse 2) – (leading edge of first cycle of pulse 2)
Then pulse width is
tpw3=4*6.33m+4.75m
=30.07m
Choose
C4=100n
R5=273.48k
Then
tpw = 1.1*R5*C4
=1.1*273.48k*100n
=30.08m as required (nearly)
The circuits for pulses 1 and 2, when run individually – not connected to other circuits – do produce the required values. If I run the circuit for pulse 3 on its own, output just stays high, and does not return to low.
The measurement I’m interested in is at OUT2. As I said, it’s not correct. The up time for the 1st and last pulse in a cluster is either too long, or too short.
I have tried connecting the 555s in a million different ways, but have had no luck. Any help will be much appreciated.
THANKS!
  • 555 pulses.asc
I take it there are NO constraints on the values you choose. However, should you build it in the lab, you will be restricted to an EIA standard value.
Using the EIA E12 series for capacitors and the EIA E24 series for resistors, you can get the 1000 Hz within a couple of Hz and a duty cycle of 76 percent.
As far as combining the signals to produce the output as displayed, you are working with digital levels, assuming the professor wanted you to use the +5 Volt supply.
  • Like
Reactions: NLT
No. No restrictions. I will rework everything to use standard values, but that still doesn't solve my problem.
Voltage wasn't specified, but we have been working with 5V thus far, so I kept it like that.
To start with, 555's don't like 5v.
Well, the Fairchild datasheet for the 555 says that the minimum supply voltage is 4.5v.
I expect Colin reads that as "5.4V" in Australia :D.
The LMC555 is a Cmos 555 and its datasheet says, "1.5V supply operating voltage guaranteed". The TLC555 and ILM555 work from a supply voltage down to 2V.
NLT
You are not synchronizing the three timers so the sequence is set the way you want it.
Review the datasheets and application notes carefully.
