hi
this sample is to send any rc5 code without Keyboard is adaptation of ATTiny2313 sample
'Name : 36KHzKey6.bas
'By Mic-Josi 2013/02 build 1.0
'Language BASCOM AVR build 2.0.7.5 Demo Version
'purpose : RC5 code 36KHz by Timer0 CTC mode
'micro : ATTINY45
'suited for demo : yes
'sample adaptation of sample RC5 ATTiny2313 "rc_tx1a.bas"who run with 12 keys' keyboard
'this sample run without keyboard only set "Key" for command and Rc5_address for device
'in this sample the French TV channel is selectionned "Key = 6"
'you must Setting a Divide clock by 8 FuseBit to OFF
$regfile = "attiny45.dat" ' microcontroler
$crystal = 8000000 '8 Mhz internal oscillateur
'****** you can also use theses settings with an ATTiny13******* not tested
$hwstack = 16 ' use 16 for the hardware stack
$swstack = 16 ' use 16 for the SW stack
$framesize = 16 ' use 16 for the frame space
Dim Key As Byte Simule L 'simulate keyboard key pressed
Dim Rc5_bit_nr As Byte ' device adresse "0 = TV"
Dim Toggle_bit As Boolean ' repeating key
Dim Rc5_address As Byte ' channel selection "6"
"Dim Rc5_command As Byte
Const Carrier_on = &B01000000 'IR 36kHz carrier on
Const Carrier_off = &B11000000 'IR 36 KHz carrier off
Declare Sub Logic_0 'bit 0
Declare Sub Logic_1 'bit 1
Config Timer0 = Timer , Prescale = 1 , Compare A = Toggle , Clear Timer = 1
Timer0 = 0
'110 = 36KHz 104 = 38 KHz
Ocr0a = 110 '36KHz carrier
Tccr0a = Carrier_off
Toggle_bit = 1 ' ask for répétition
Rc5_address = 0 ' TV device
Do
Key = 6 ' channel 6
Waitms 1
Ddrb.0 = 1
'set OC0 (Pb.1) = IR LED carrier out
Logic_1 '1er start bit
Logic_1 'second start bit
If Toggle_bit = 0 Then Logic_0 Else Logic_1
Rc5_command = Lookup(key , Rc5_commands) 'reding data commande RC-5
For Rc5_bit_nr = 4 To 0 Step -1 '5 bit addresse, msb first
If Rc5_address.rc5_bit_nr = 0 Then Logic_0 Else Logic_1
Next
For Rc5_bit_nr = 5 To 0 Step -1 '6 bit commande, msb first
If Rc5_command.rc5_bit_nr = 0 Then Logic_0 Else Logic_1
Next
Waitms 87 'trame delay
Loop
End 'end program
Sub Logic_0
Tccr0a = Carrier_on
Waitus 883
Waitus 884
End Sub
Sub Logic_1
Waitus 883
Tccr0a = Carrier_on
Waitus 884
End Sub
Rc5_commands:
Data 1 , 2 , 3 , 0 'column 4 not used (3x4 keypad)
Data 4 , 5 , 6 , 0
Data 7 , 8 , 9 , 0
Data 10 , 11 , 12 , 0
