    Dismiss Notice
+/-33V outputs - What opamp could I use?
Discussion in 'General Electronics Chat' started by atferrari, Feb 11, 2012.
  1. atferrari
    atferrari Well-Known Member
    Oct 8, 2003
    2,700
    116
    Buenos Aires - Argentina
    I wonder if is it possible to do something similar to what is proposed here
    http://www.electro-tech-online.com/threads/pwm-signal-to-lm317-to-adjust-voltage-output.125091/
    but this time to get two control signals: one from 0 to +33V to control an LM317 and another from 0 to -33V to control an LM337.
    I imagine two separate opamps, one powered between 0 and +38V and the other between -38V and 0V. (I have those +/-38V DC available from an old power supply).
    What could be the most suitable opamps?
    Searching through Farnell I can at least compare some but the prices of the suitable(?) ones is scary. To come to my hands I have to think of them multiplied around 4 times!!
    Maybe I am overlooking something...
    Any suggestions? Gracias
  2. MrAl
    MrAl Well-Known Member Most Helpful Member
    Sep 7, 2008
    10,862
    935
    NJ
    You think you could post a schematic rather than have us search through a bunch of posts to see what you actually want to do? I think this would help a lot for people reading this thread. I know it would help me to understand you better.
  3. alec_t
    alec_t Well-Known Member Most Helpful Member
    Jul 10, 2011
    8,809
    1,150
    Cardiff, Wales
    If I understand you correctly you want one PWM signal to give two simultaneous outputs; one of them negative (0 to -33) and the other positive (0 to 33) ?
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. atferrari
    Oct 8, 2003
    2,700
    116
    Here it is
    I believed it was better to read about the idea until reaching the circuit. But OK, that is me.
    Here it is
    http://www.electro-tech-online.com/threads/pwm-signal-to-lm317-to-adjust-voltage-output.125091/#post1036064
    Two independent PWM signals; each one controlling one regulator. That is why I think of having them powered between common and its respective rail (single supply).
    My concern is the type (and COST) of the opamps I could use.
  6. alec_t
    Jul 10, 2011
    8,809
    1,150
    Cardiff, Wales
    The op-amps themselves aren't critical as they don't have to withstand 33V. You could run them at, say, 12V and use them to drive BJTs or FETs switching loads operating from 33V.
  7. ronsimpson
    ronsimpson Well-Known Member Most Helpful Member
    Apr 17, 2007
    6,641
    846
    Loveland, CO USA
    ONLINE
    High voltage op amps are not so common but:
    AD8274
    ADA4004
    LTC6104, LTC6103, LT1013
    AD5749
    OP4177
    PA340CC
    PA341CE
  8. alec_t
    Jul 10, 2011
    8,809
    1,150
    Cardiff, Wales
    Perhaps this? Almost any opamp (I used a LM324 model) with rail to rail input will do. Not having a LM317 or LM337 model I used LT1085 and LT3015 respectively. There are two 0V to +5V PWM inputs (from a micro). One opamp has a 5V supply, the other a -5V supply. The regulators have +33V and -33V supplies respectively.
  9. atferrari
    Oct 8, 2003
    2,700
    116
    Will try it.
    Busy with vessels right now but I will try it.
    Gracias.
Share This Page
