2sc1061 equivalence
tty82
Hello,
I'm searching for the equivalent of the 2sc1061 either a or b at the end.
It's part of my father's 4VN-550 JVC amp that I'm trying to resurrect.
On the transistor it only writes "C1061", I managed to find the service manual of the 4VN-770 where they mentioned the full code.
I have already searched the equivalence on the web and the only thing that came up usefull was here:
But the result has the transistor in multiple columns and lines. Are all these equivalent?
EQUIVALENCE RESULT
ECG152 2SD235 2SC1061 2SD313 2SC789
2SC790 2SD526 2SC789 2SD235 2SC1061
2SC1060 2SC1061
2SC1061 2SD313 ECG152 2SD526 2SD235
2SC1419 2SC1173 2SD330 2SC1061
2SD234 2SC1061 2SD313 2SD235 2SC790
2SD313 2SD235 2SC1061 2SC790 2SD234
2SD317 2SC1061 2SD313 2SC790
2SD318 2SD313 2SD234 2SD235 2SC1061
2SD856 2SC1061 2SD313 2SD235
146856 2SD235 2SC1061 2SD313 2SC789
146855 2SD235 2SC1061 2SD313 2SC789
121-966 2SD313 2SD235 2SC1061
142691 2SD235 2SC1061 2SD313 2SC789
132573 2SD235 2SC1061 2SD313 2SC789
Thank you
european equivalent
My Jeager guide gives bd243c as pincompatible replacement. Data: 50V, 3A, 25W, 8Mhz.
Regards pa3bwi
Oeps before I forget, answhere to your original question,
2SC1061 2SD313 ECG152 2SD526 2SD235, last 4 are equivalents. Since equivalents are usually more heavy types or with better spec's you cannot use the other lines without checking the datasheets for these transistors,
Regards PA3BWI
Thanx everybody did find the 243c at my local electronics shop today .
It's up to soldering now.
Trully thanx :)
