16f1503 to 16f676 conversion
sahu
hi everyone
Today I'm facing problem with 16f676 adc reading.
Actually i want convert micro controller. That code works fine with 16f1503 but when i convert it 16f676, adc readind reading function not work.
16f1503.h
#include <16F1503.h>
#device ADC=11
//#FUSES WDT                      //Watch Dog Timer
#FUSES NOMCLR                   //Master Clear pin used for I/O
#FUSES PROTECT                  //Code protected from reads
#FUSES BORV25                   //Brownout reset at 2.5V
#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
#use delay(internal=4000000,restart_wdt)
//#use rs232(baud=9600,parity=N,xmit=PIN_C4,rcv=PIN_C3,bits=8,stream=PORT1)
#use FIXED_IO( A_outputs=PIN_A5,PIN_A2,PIN_A1 )
#use FIXED_IO( C_outputs=PIN_C5,PIN_C3,PIN_C2,PIN_C1,PIN_C0 )
16f1503.c
#include <sta_1503.h>
#include <math.h>
void main()
init_peripheral();
/******Timer Init*******/
      output_low(RLY1_TMR); output_low(High_Low_LED);output_low(TIMER_LED);
      setup_timer_1(T1_INTERNAL|T1_DIV_BY_8); //524 ms overflow
      enable_interrupts(INT_TIMER1);
      enable_interrupts(GLOBAL);
      delay_ms(1);
/******* End of ADC Init*******/
/******* Start of Peripherial *******/
      output_high(Buzzer);output_low(TIMER_LED);output_low(RLY1_TMR);
      output_low(RLY2);output_low(RLY3);output_low(RLY4);output_low(RLY5);
      system_tick = 0;
   /******* End of Peripherial *******/
   delay_ms(10);
   relay_voltage();  output_low(Buzzer);
  while(TRUE)       //Master Loop
   {   ///to do something
//Reading A/C Voltage
long read_ac_voltage(void)
unsigned char i;
long adc_value;
long peak_value=0;
set_adc_channel(0);
delay_ms(1);
         for(i=0;i<=40;i++)
            adc_value = read_adc();
            if(adc_value > peak_value)
             peak_value = adc_value;
            delay_us(500);
         peak_value = (peak_value*0.266);
         return peak_value;
long read_timer_value(void)
            long adc_value;
            set_adc_channel(3);
            delay_ms(1);
            return adc_value;
void init_peripheral(void)
   set_tris_a(0x08); // RA3 TMR_relay reset
   set_tris_c(0x10); // RC4 reset
   /*******ADC*******/
   setup_comparator(NC_NC_NC_NC);
   setup_adc(ADC_CLOCK_DIV_32);
   setup_adc_ports( sAN0|sAN3| VSS_VDD);    //RA4 as timer value adc
   set_tris_c(0x10);  // Set Pin RC4 as input, Timer reset
   port_a_pullups(0x08);//pull up on port a3
   port_c_pullups(0x10);//pull up on port c4
Now pls guide me about 16f676 !!!!!!!
i do as for 16f676
/#include <16F1503.h>
//#device ADC=11
#include <16F676.h>
#device ADC=10
//#FUSES BORV25                   //Brownout reset at 2.5V
//#FUSES NOLVP                    //No low voltage prgming, B3(PIC16) or B5(PIC18) used for I/O
//#FUSES WDT                    //No Watch Dog Timer
#FUSES INTRC_IO                 //Internal Oscillator @ 4 Mhz
//#FUSES BROWNOUT               //No brownout reset
#FUSES NOMCLR              //No brownout reset
//#use delay(internal=4000000,restart_wdt)
#use delay(clock=4000000)      // 4 Mhz Clock
#rom 0x3FF = {0x3480}[/code
