    Dismiss Notice
~150V DC Regulator?
Discussion in 'General Electronics Chat' started by Berserk87, Sep 15, 2009.
  1. Berserk87
    Berserk87 New Member
    May 14, 2009
    77
    0
    is there such thing as a regulator that can handle around 150V DC?
    preferably a buck converter, not something that just turns the extra energy into heat.
    ive been searching, but all the ones im finding are 80V input max.
  2. RCinFLA
    RCinFLA Well-Known Member
    Jul 23, 2009
    1,065
    31
    FLA, USA
    All the cheap A.C. inverters have a high frequency switching boost transformer power supply that creates about 155 vdc output. This is followed by a MOSFET H-bridge that creates the modified sinewave output to A.C. socket.
    If your are looking for 150 vdc from A.C. mains I am sure there is switching power supply out there somewhere.
  3. Electronworks
    Electronworks New Member
    Aug 23, 2009
    204
    2
    Try having a look at Power Integrations. They work off rectified (and smoothed) ac which is the same as dc..
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. Berserk87
    May 14, 2009
    77
    0
    :confused:
    im trying to take 150VDC down to something around 40VDC.
  6. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    What sort of current?
  7. Berserk87
    May 14, 2009
    77
    0
    150V input , 32V ouput at 1Amp.
  8. bountyhunter
    bountyhunter Well-Known Member
    Jul 17, 2009
    1,560
    81
    You could easily build a buck to do that. However, it would be running at only 20% duty cycle so it wouldn't be real efficient.... still way more efficient than a linear.
  9. Berserk87
    May 14, 2009
    77
    0
    Any links or suggestions? The only bucks I've "designed" are using national semiconductors web bench, and they don't seem to have a solution for what I need.
  10. Speakerguy
    Speakerguy Active Member
    May 24, 2007
    1,473
    15
    USA
    What is your load? A DC source, or does transient response matter?
    You can totally made a DC/DC converter without some pre-fabbed chip or module meant for that purpose. The dsPICs are used a lot for power converter 'brains'.
  11. Berserk87
    May 14, 2009
    77
    0
    It doesn't matter, the load would be a bunch of LEDs and a possibly a micro controller or other simple things.
  12. bountyhunter
    Jul 17, 2009
    1,560
    81
    As loathe as I am to throw NS business, you could probably use a 400V PNP or P-FET as the power pass device bucking the main DC input, and use a switcher IC to drive an NPN with it's emitter grounded whose collector pulls down on the P buck transistor. There are probably a bunch of generic switcher controllers you could use, you will have to create a lower voltage rail like 20V to run the IC maybe with a power resistor and zener down from 150V. That bias voltage rail can be poorly regulated, doesn't matter.
  13. Mr RB
    Mr RB Well-Known Member
    Jul 22, 2008
    4,716
    194
    Out there
    Just buy a 110v mains to 32v DC switchmode supply. That will work fine from 150v DC input instead of 110v AC.
  14. RCinFLA
    Jul 23, 2009
    1,065
    31
    FLA, USA
    Regular AC switching power supply will work from 150 vdc.
    Just don't get a power factor corrected power supply.
    If you want you can bypass the rectifier bridge in the switching power supply.
Share This Page
