    Dismiss Notice
15" LCD TV's
Discussion in 'Repairing Electronics' started by James111, Nov 6, 2008.
  1. James111
    James111 New Member
    Nov 5, 2008
    4
    0
    Hello to all. 2 years ago I purchased 14 Phillips/Magnavox 15" LCD tv's, refurb's, for school use. Since then I have had 3 of these go bad. It is always the same, first the video will go blank after 15-20 minutes, shut it off, wait a few minutes and turn it back on. It soon gets to a point where you no longer have any video ever but good sound. I see many of these sold for parts on the net so I believe there is a very common problem. Can anyone help me out as were to look or shed some light on these failure. I have pressed everywhere on the board while it is on to see if video would return but it doesn't. Thank you for any help, Jim
  2. picbits
    picbits Well-Known Member
    Jan 29, 2007
    1,996
    93
    Northants, United Kingdom
    As per the other thread with a similar problem, go through all the electrolytic capacitors first and test/replace the dodgy ones.
    They dry out with heat and age.
  3. picasm
    picasm Member
    Sep 6, 2006
    358
    3
    UK
  4. dave
    Dave New Member
    Jan 12, 1997
    0
  5. MrAl
    MrAl Well-Known Member Most Helpful Member
    Sep 7, 2008
    11,026
    951
    NJ
    With my monitor i had way too many electrolytics to go through all of them.
    I'd say there were about 50 in there. Some where for control and not
    power supplies, so if i only looked at the ones used for the power supplies
    (guessing a little as to which ones) i'd still have to go through about 20.
    Im not sure i wanted to desolder one lead of all those caps.
  6. Magen
    Magen New Member
    May 29, 2008
    51
    0
    Johannesburg,South Africa
    Hello,
    Try looking at the caps closest to heatsinks/heat sources first. They're usually the first to go.
  7. James111
    James111 New Member
    Nov 5, 2008
    4
    0
    LCD TV's
    Thank you for your help. I have already paid and downloaded a diagram to assist in locating the problem. I'll check the caps suggested by other threads. again thank you , Jim
  8. Nigel Goodwin
    Nigel Goodwin Super Moderator Most Helpful Member
    Nov 17, 2003
    39,203
    640
    Derbyshire, UK
    That's why you use an ESR meter, it checks the capacitors in-circuit, and checks for what goes wrong with them - you can also use a scope to check for ripple, but that requires it powered up and running.
  9. blueroomelectronics
    blueroomelectronics Well-Known Member
    Jan 21, 2007
    12,536
    168
    Toronto, Canada
    What program is that? It helps troubleshoot LCD TVs?
  10. picbits
    Jan 29, 2007
    1,996
    93
    I guess maybe he has found Euras or similar.
  11. Mikebits
    Mikebits Well-Known Member
    May 24, 2008
    6,214
    174
    San Diego, Ca
    Best tool for this type of problems is a can of Freeze spray and a heat gun. Works like a charm. This method only works when the set is temp-ermental :)
  12. James111
    James111 New Member
    Nov 5, 2008
    4
    0
    15' LCD's
    Tanks to all for your suggestions. I have given many of these a try but to no avail. I was hoping there must be a very unique problem that is common to all of these but sometimes it's not that easy. Since they were refurbs in the first place, it's hard to warrant a lot of time let alone parts locating. I just don't like to throw away the entire unit for just one small bad cap. More products today should be repaired instead of just chucking. Again, thanks for all the help, Jim
  13. francis10gh
    francis10gh New Member
    Jul 22, 2007
    1
    0
    Ghana
    did u check n replace the capacitor?
    u sould replace the long ic on the board.
  14. Mikebits
    May 24, 2008
    6,214
    174
    San Diego, Ca
    Of course you must realize, there is more than 1 cap on the board. Many to be exact.
  15. PaulAdman
    PaulAdman New Member
    Nov 21, 2008
    6
    0
  16. MrAl
    Sep 7, 2008
    11,026
    951
    NJ
    Hi Nigel,
    Thanks for the great idea about the ESR meter. It's too bad i dont
    own one though, but if i did i would certainly give this a shot.
    Im not sure if it would pay for me to buy one just to fix this one CRT
    now though, and then if something else went wrong with it i would
    be a bit sorry :)
    It's too bad too because electrolytics arent that expensive and i
    have a bunch around already too.
    In the future i'll have to keep this idea in mind however, in case
    i spot a sale on an ESR meter.
    I have a wave generator and scope but im too lazy to try that.
    Also, i like the smaller space the LCD takes up now so maybe
    i'm hooked on LCD's now. In the future though i think i'll look
    for a better LCD as i seem to have gotten a cheapie now.
  17. Nigel Goodwin
    Nov 17, 2003
    39,203
    640
    Derbyshire, UK
    As you have a scope, check for ripple on the supply rails - this is mostly what low ESR caps cause.
  18. MrAl
    Sep 7, 2008
    11,026
    951
    NJ
    Hi Nigel,
    Well the unit would not power up, that was the problem.
  19. Nigel Goodwin
    Nov 17, 2003
    39,203
    640
    Derbyshire, UK
    The unit not powering up, and the PSU not powering up are VERY different things - are none of the supply rails working?.
  20. MrAl
    Sep 7, 2008
    11,026
    951
    NJ
    Hi again,
    Well, now i gutted it for parts :)
  21. aquamon
    aquamon Member
    Nov 29, 2008
    96
    0
    Oh my.
    Oh my.
    Oh my.
    FAILURE!
    Mr. A1 Sauce?,
    If you have a DMM, get yerself a damned ESR meter or build one yourself (google it)!!!
    I myself bought and use a CapAnalyzer88A, couple years later I added another DMM from world-wide-wars dot mouser dot com, Amprobe 34XR-A.
    Some caps that pass with the CapAnalyzer fail with the Amprobe!!!
Share This Page
