12Volt power supply voltage drop problems
mondo8205
Its a 120Vac to 12Vdc power supply for a camper. I have it pulled apart and it works fine and outputs 12Vdc with no load, when I put a load on it, the voltage drops and makes a slight buzz sound.
Suggestions or where should I start???
are you sure it's a 1A load? describe the power supply. does it have sense terminals? if so are they connected to the output, or left open?
pix would help
That 8-legged chip at the bottom left of the pic looks cooked?
I see what you mean, but I am not convinced.
Looks more like a blob of paint/varnish/sticky-stuff to me.
Have you done a diode check on the mains input rectifier diodes? I can't see them on the pic, so presume they're on the heatsink?
I think they would normally run hot even if the supply were working ok.
I can now see (bottom pic) where the spade connectors go to the input bridge rectifier on the heatsink. Have you checked its diodes are ok? If a diode has failed and you're only getting half-wave rectification then your supply will be struggling to give much output.
No, I'm talking about the black thing with a bolt through it, on the right side of the last pic in post #11, which the red, black and white wires connect to with pull-off spade connectors. Isn't that a bridge rectifier?
oh yea its a bridge rectifier.
I applied currents and measured voltage drops and 1 of the 4 diodes was busted!
So you think that one diode would cause the power supply to output 12v then drop with load?
Well part has been ordered and after I replace it, I guess we will find out if that was the only problem.
Thanks guys!
Yes I do :)
With a failed diode the mains input voltage is only half-wave rectified, so when any appreciable current is drawn from the supply the voltage on the input reservoir capacitor drops way below where it should be. This means the switch-mode section of the supply has insufficient input voltage/power to operate properly and deliver its rated output.
