Re:code -- I put the cursor in the code box and click ctrl+A, copy. Then paste into notebook or whatever code editor you use.
John
hi everyone,
i like the site a lot but if anyone is looking for ideas to make some changes or improvement, maybe consider two things that i run into:
1. code surrounded by CODE tag displays as expected but selecting and copying larger code samples could be simpler. for example clicking into code and typing CTRL+A selects everything on a page instead of all code. is there an easy way out? perhaps textbox or a button "copy all code"?
2. when posting reply, i tend to check if original poster added more detail. due dynamics of the site where new posts are added all the time, it is easy to loose track of the thread. what i do is check "my posts". this almost does the job but it does not give me option how to sort them. it goes by latest post (which is usually fine) but i wouldn't mind more control (sort posts by time of my post, sort by number of replies etc.).
thank you
John
when i do that, Ctrl+A selects not only text within code tags, but the entire page, hence copying and pasting to notepad with this method produces huge mess, too huge to clean by hand. it is easier to use mouse and select code by hand, then copy and paste. btw, i'm using Chrome, not sure if other browsers behave differently.
The click on the first character to set the cursor, then scroll to the last character, shift+click to select the whole code block, etc. I guess that is similar to what you are doing. At least it works
I use Chrome too.
John
That is not what I said in my second post. Don't click ctrl +A
John
sorry John,
misunderstanding - i know i can do that - and i do - but... i don't quite like it
what i would like is - eliminate scrolling.
| Similar Threads | ||||
| Thread | Starter | Forum | Replies | Last Post |
| Issues with PIC16F877A and LCD display... | si2030 | Microcontrollers | 19 | 10th April 2010, 09:31 AM |
| Changing and modifying Code | divit | Microcontrollers | 5 | 19th November 2008, 07:10 AM |
| Arm 7t and C++ code | Gaza2k1 | ARM | 5 | 21st November 2007, 10:07 PM |
| need help with a small doubt with PIC and verilog code | sal | Microcontrollers | 6 | 9th February 2007, 03:24 PM |
| Start up and Initialization code | Bella | Microcontrollers | 0 | 29th October 2003, 02:38 AM |
