Best accelerometer for balancing robot
  1. #1
    Varunme Varunme is online now
    which is the best acclerometer for a self balancing robot ?
  2. #2
    misterT misterT is offline
    Probably the most sensitive one. The mounting place of the sensor is more important than the sensor itself. How big is your balancing robot?
    0
    "I cannot prove it because it is too basic. Every mathematician knows that the simplest things are the hardest to prove."
  3. Thread Starter #3
    as bigger as the one i can easily stabilize, since smaller ones are difficult to stabilize ....
    0
  4. #4
    Very difficult to give answers with so little information. Choose the most sensitive 2 or 3-axis accelerometer from the cheap end of the price end. Make sure that the sensor has an interface that you can use (analog, i2c, spi).
    Try to find a module that is already soldered to a pcb because most of the accelerometers are in very small "no-leads" packages and are therefore difficult to solder (for hobbyist).
    http://www.pololu.com/search?query=a...ometer&x=0&y=0
    Edit: This could be a good choice if analog output interface is ok for your product: http://www.pololu.com/catalog/product/1246
    +1
  5. Thread Starter #5
    yes,
    i want to build two wheel self balancing robot,
    with geared dc motor, at a size, which can be easily balanced,
    later i want to mount other parts to the robot with the self balanced base as the basement for the robot.
    0
  6. #6
    Triode Triode is offline
    I used one of these for a robotics project recently and it proved very sensitive and easy to use. If you leave the g select pin disconnected it will be in 1 g mode, besides that just give it power and pull the slp (sleep mode) pin high to turn it on.
    http://www.sparkfun.com/products/9652
    +1
    -Paul
  7. #7
    fermat7 fermat7 is offline
    Hey...
    I can advise you ADXL series , i tried that before in some projects related to heading and balancing UAVs. you can check for more details according to your needs.
    0
Best disassembler for 16C62A? kentken Microcontrollers 10 16th August 2009, 07:18 AM
Best PDA for interfacing / programming jeanseb Electronic Projects Design/Ideas/Reviews 4 29th July 2004, 02:11 PM
Looking for RF circuits for my robot baohead Electronic Projects Design/Ideas/Reviews 6 20th July 2004, 05:56 AM
Camera for my robot Kyma Robotics & Mechatronics 0 19th June 2004, 07:35 AM
best sensor for fan monitoring jcaluma Electronic Projects Design/Ideas/Reviews 8 22nd April 2003, 09:49 AM
Page Time: 0.08615 seconds      Memory: 7,450 KB      Queries: 16      Templates: 0
