Old 25th October 2009, 10:11 AM   #1
Default confused with phototransistor and TSOP .... help me plz!
hi......!
i am a beginner plz help me to get rid of my confusion.
i wanted to create a line follower obstacle detection and photo phobe and etc..
i generally know about LDR and photo diode but while searching for line follower circuits read about many circuits and got confused about what i know before also.
1)what is photo transistor?is it not the photo diode?what is the difference between them?does it also have rx and tx pair or only a single one?
2)what is TSOP 1738 what for it used for ?is it not same as photo diode?
how is it different from photo diode?does it also have emitter and receiver modules?are there different varieties of tsop available?
please explain me case wise.
thankq..
srikapardhi is offline
Old 31st October 2009, 10:48 AM   #2
Hi
Internally a phototransistor is very different compared to a photodiode. However, externally they appear very similar.
In a photodiode the inverse leaking current depends on the amount of light.
In a photo transistor the light is like the base current. The collector-emitor current is an amplified version of the base current induced by the light. A photodiode is therefor more sensitive then the Photodiode.
In this tutorial a photo transistor is used to measure light with a phototransistor:
http://www.dwengo.org/tutorials/light-measurement
Slorn
Dwengo... gets you started with microcontrollers!
Slorn is offline
Old 2nd November 2009, 10:57 PM   #3
A photo-diode can be used two ways;
1) It leaks a small current when it has a reverse bias voltage and light.
2) It is a small solar cell that produces a small current when it has light.
A photo-transistor leaks current like a photo-diode when its collector has a voltage and has light but the transistor has gain so it is more sensitive than a photo-diode.
An LDR is a light sensitive resistor that responds slowly.
audioguru is offline
confused, phototransistor, plz, tsop
:confused:Help in numeric keypad concept.:confused: xxxnonoxxx Micro Controllers 6 25th May 2007 02:07 PM
:confused:Capacitor Advice:confused: Memphis_Raines General Electronics Chat 9 28th December 2006 09:40 PM
problems with TSOP mathewctom General Electronics Chat 3 6th November 2006 06:38 PM
Soldering TSOP patroclus General Electronics Chat 11 29th August 2005 11:27 AM
TSOP 1738 infinity Robotics Chat 2 24th October 2004 06:24 PM
