Old 21st October 2009, 07:19 PM   #1
Default two communicating line followers
my project requires my two line followers to communicate with each each other wirelessly. basic requirement is that one bot should be able to power on/off the other. an ideas on how this could be achieved.?
shreyasjk is offline
Old 22nd October 2009, 02:57 PM   #2
are you 100% sure you need to power on the other one and not "start/stop the motion" of the other one as if you power it off, it cannot receive power on command?! You can stop it, and start it, but it has to be powered on in order to listen to commands.
except start/stop what else you want them to talk about?
do you have "line of sight"?
if you have line of sight the easiest way to make them talk is IR. You have IR communication examples in Nigel's tutorial: Nigel's PIC Tutorial Page
arhi is offline
Old 22nd October 2009, 03:18 PM   #3
yes you are right. it should be able to start/stop the other bot. what exactly do you mean by "line of sight"?? i'm a newbie, so bear with me. thanks for the reply.
Old 22nd October 2009, 09:06 PM   #4
line of sight mean that there is no obstacle limiting light going from one to another. For example if they are in separate rooms. The IR communication works like your TV remote, you have to have line of sight between remote and TV for remote to be able to send signal to TV what to do. Here is the same thing, if you have the line of sight you can use IR for them to talk to each other. If you do not have line of sight you have to go with RF and that require transmit and receive circuits that are not easy if you want them not to drift too much... you can get some failry cheap transmitter modules with low quality, slow speed and low range but they will work, or you can go more expensive or even digital with BlueTooth or Zigbee...
I suggest you first try simple communication with IR as explained in Nigel's tutorials. If you do not have much experience, I suggest you first go trough all Nigel's tutorials before you start your project.
arhi is offline
communicating, followers, line, line follower, robot
Communicating with a mobile phone via IrDA Hero.sl Robotics Chat 8 25th October 2009 08:35 PM
communicating two pic16f877 using IR ruki009 Micro Controllers 1 24th June 2009 01:43 AM
Communicating with SRF05 using PIC18f452 jagjit.sehra Robotics Chat 11 13th February 2008 05:13 PM
Simplest way of communicating via RF Cry_Wolf General Electronics Chat 7 13th January 2008 03:44 AM
Updated today the Cricket Communicating Thermostat William At MyBlueRoom Electronic Projects Design/Ideas/Reviews 0 6th April 2006 05:44 AM
