We have this project on an object tracking robot. It uses an onboard webcam to take images, which are sent to a computer and processed in Matlab to identify the target position and the computer generates the control signals for the movement of the robot. The problem is that there is no parallel port in our laptop. So we are thinking of sending the data to the usb port and then somehow making it parallel data. When i googled "usb to parallel", i could see that many usb to parallel port converters are available. Id like to know if we can use those converters? Or is there a simpler method to convert the serial data from usb to parallel? Thanks | |
use FTDI chip example: FT245BM or if that's complex for you, get a ready made FTDI module example: UM245R DIP Module
__________________ Bits From Bytes - the best RepRap kit out there now featuring RepRap V3 with full electronics redesign based on PIC32MX440F256H (English) MySQL Blog (Serbian) Elco Blog (Serbian) Use forum to ask questions, do not use PP | |
yes there are plenty of USB to Serial adapters available. Recently I bought such an adapter called HL USB-RS232. I think thats a chines brand. I'd not recommend you to buy that because I'm still experiencing difficulties using that with Windows HyperTerminal. Sometimes it works perfectly but sometimes not Used it with a custom C# app and it worked fine.
| data, parallel, usb, usb to parallel |
| Usb Digital I/o / Parallel Port | Briam | Electronic Projects Design/Ideas/Reviews | 18 | 28th July 2009 10:39 AM |
| Parallel, serial or USB? | chris414 | General Electronics Chat | 10 | 2nd May 2009 04:30 AM |
| USB instead of parallel port | kashthealien | Micro Controllers | 11 | 16th June 2008 04:10 PM |
| USB to Parallel HELP! PLZ! | demestav | General Electronics Chat | 11 | 13th April 2005 12:44 AM |
| USB to Parallel Cable | AZdave | Micro Controllers | 2 | 5th January 2005 12:38 PM |
