Old 11th October 2009, 07:44 PM   #1
Default Circuit relase component
Posted this in the wrond section, so reposting here:
Complete newby to electronics, but have a basic understanding. Have an idea for a little project and tried searching the net and couldn't find a component or its technical term, what I am after is a component that when built into a basic battery operated circuit works as a "release" in that when the circuit is off the (say for instance pencil) is held, but when the circuit is switched on, the component (possibly a claw) opens to release what it is holding. Not sure of its technical term, so having difficulty finding anywhere that stock such an item. I'm only talking about a cheap item, basic device which opens when circuit is switched on, incorperated into a basic circuit powered by a 9v battery.
Thanks in advance! and sorry for the crude nature of the question.
wod is offline
Old 12th October 2009, 04:40 AM   #2
a solenoid will have two positions, one (held by the spring) will be "open" and other (when voltage is applied) will be close. It is actually linear actuator with 2 positions. You will not have "speed control", "pressure control", "position control" - it is just a piston set fully left or fully right (or up/down, front/back, however you turn it). You can attach anything on that piston (a claw for e.g.) in order for it to "grab/hold".
Solenoids Catalog - Magnetic Sensor Systems
You can also make a grapple using servo's, steppers and other motors that will give you more precise control (speed, position)
arhi is offline
Old 12th October 2009, 09:34 AM   #3
Also you could look at any of those cheap little DC gearmotors they sell like the Tamiya ones.
Mr RB is offline
circuit, component, relase
Adding a component to a simple 2n7000 circuit mabauti Electronic Projects Design/Ideas/Reviews 5 21st September 2008 12:02 AM
Uncertain what component used in the circuit aviro25 Electronic Projects Design/Ideas/Reviews 2 13th March 2008 12:26 PM
unknown component/ circuit chinsoon General Electronics Chat 6 3rd November 2006 04:42 PM
Suitable component for this stun gun circuit. gbyg General Electronics Chat 0 23rd March 2006 07:48 PM
circuit efficiency and component question bonanz General Electronics Chat 8 17th November 2003 12:05 AM
