Old 10th October 2009, 04:22 AM   #1
Default Stepper Motor Controller Possible?
Would I be able to rotate a stepper motor 360 degrees and stop with the click of a button and it would only spin when a wireless signal from a transmitter told it to (like a wireless button pushed in; separate from the driver board). Is this a possibility? Powered remotely. Thank you.
gladiator11 is offline
Old 10th October 2009, 05:57 AM   #2
To directly answer your question, yes it's possible. What part of the project has you stuck so we could help you more?
MoonTaj.com - Lead developer
All around tech enthusiast.
jimlovell777 is offline
Old 10th October 2009, 03:27 PM   #3
Ok basically, I don't know where to start. I need a circuit board design to operate such a sequence. Thank you for your response. By the way, I live 5 minutes from St.louis, MO =]. Nice to meet you.
Old 11th October 2009, 02:59 AM   #4
Nice meeting you as well. Are you familiar with coding or microcontrollers? Do you have an idea of what you want to use for a transmitter and receiver pair?
Old 12th October 2009, 12:36 AM   #5
I'm afraid my knowledge of electronics is very slim.
Old 12th October 2009, 09:32 AM   #6
You might be better off with a simple DC motor, and put a cam on it, and a switch on the cam. It will turn 360' then stop. Heaps of old machines used a system like this.
Then you just need a 555 timer to start it up each time.
Mr RB is offline
Old 13th October 2009, 01:28 AM   #7
Hmm... much rather use a stepper motor. Can't afford the switch/catch latch vibrations.
Old 13th October 2009, 08:38 AM   #8
Don't want vibrations????
I'm guessing you don't use stepper motors much then??
Mr RB is offline
Old 18th October 2009, 05:37 PM   #9
Well, how could I control a DC motor to turn and stop 360 degrees around? - Without using a lever switch...
Old 18th October 2009, 05:40 PM   #10
Use an optical switch like an IR photo interruptor.
Mr RB is offline
Old 18th October 2009, 06:05 PM   #11
Great point, was thinking of that but wasn't sure how precisely it would stop. I really need it to stop nearly exact to 0-360 degrees. Also, I'm assuming DC motors more efficient than stepper motors?
Old 19th October 2009, 06:35 PM   #12
For DC motor at low speed, a big part of the input power goes to heat, just a little goes to movement.
Grossel is offline
Old 19th October 2009, 07:58 PM   #13
You'd need to count the number of steps of the stepper motor and then make the stop pin high, so turning 360deg and then stopping isn't as easy as it first sounds.
Froskoy is offline
Old 19th October 2009, 11:19 PM   #14
Another factor you need to take in account when operating steppers: In general, you don't know the position of the stepper. So you must make a procedure that run the stepper "backwards" until some button is touched. That's the first thing to do.
Grossel is offline
Old 20th October 2009, 02:03 AM   #15
Ok, can I just use a brushless dc motor + controller and an IR photo sensor to stop it at 360 degrees? or will that not be accurate??
controller, motor, stepper
stepper motor controller using 89c51 piyush_it1 Micro Controllers 8 9th August 2009 02:37 PM
Basic stepper motor controller ExtravDreams Electronic Projects Design/Ideas/Reviews 1 18th March 2008 04:55 PM
Stepper motor controller heepofajeep Electronic Projects Design/Ideas/Reviews 0 27th November 2006 09:47 AM
Unipolar Stepper Motor Controller Wasp Micro Controllers 2 1st November 2005 10:34 AM
stepper motor controller messymaverick Electronic Projects Design/Ideas/Reviews 4 20th August 2003 12:19 PM
