Old 21st September 2009, 04:27 PM   #1
Default which led is best
guys which led is best for line follower robot do detect white line in black background? IR or RED LED?
and can you compare advantages and disadvantages of both?
thanks
aruna1 is offline
Old 21st September 2009, 04:34 PM   #2
I would use a CdS cell (photocell). This would be easier than an IR LED which would be your second choice. They should have a bunch of schematics online. So if you google "Line Follower Robot" or something, you should come up with a number of sources. With the results you get, make sure you check if it uses a CdS cell in the schematic.
ElectroNerdy is offline
Old 26th September 2009, 06:29 PM   #3
my project also line follower, i used red and ir led but ldr didnot work that light......
pavithrams is offline
Old 27th September 2009, 01:16 AM   #4
CDS photo cells match human visual response better than most other types of sensors if I'm not mistaken. So white and black to you would be white and black to a CDS photo cell, where an IR sensor might be very different dependinig on the IR reflectivity of the 'white' surface.
Anyone that's ever played around with a black light knows that something that is white to the human eye can have dramatically different UV fluorescent abilities, and the same thing goes with IR light reflectivity but there's not a very practical demonstration to determine what an object will look like to a particular sensors without trying a variety of sensor types and determining which one is the best. Often changing the type of paper you're using, or the type of ink that's making the black line alone would be better than messing around with the sensor.
straight answer, har har."
Sceadwian is offline
led
12V Car flasher to trun on led, at the same time Flashing is on, Led is on. Tricky111 General Electronics Chat 3 18th September 2009 06:18 AM
Looking for recommendation of LED driver with individual LED PWM control tdg8934 General Electronics Chat 6 9th April 2009 09:47 PM
Does heat turn a white LED into a dim blue LED? audioguru Electronic Projects Design/Ideas/Reviews 24 6th March 2009 04:15 PM
Motion sensitive led circuit aka led coffee table gregted1 Electronic Projects Design/Ideas/Reviews 0 12th January 2009 08:13 AM
AD-501-B (w/ LC7932M LED driver ICs) 16x32 LED Display questions tdg8934 Micro Controllers 36 3rd August 2007 02:18 AM
