Old 1st August 2009, 10:37 AM   #1
Question line following robot without microcontroller
is there any other method of building line following robot other than micro controller...
jenefa is offline
Old 1st August 2009, 10:45 AM   #2
Yes, you could use a comparator.
House0Fwax is offline
Old 1st August 2009, 11:08 AM   #3
can i use lm324 comparator or any other... tell me the advantages of lm324 over other comparators.
jenefa is offline
Old 1st August 2009, 11:42 AM   #4
LM324 isn't a comparator, it's a quad opamp.
Check my site below, which contains all the details of a magazine line follower.
http://lpilsley.co.uk/cybot/light_board.htm
Old 1st August 2009, 04:42 PM   #5
lm324 is a digital ic and it can compare the voltage also, in sensor circuit it may be act as a comparator. is it right?
pavithrams is offline
Old 1st August 2009, 04:50 PM   #6
No, an LM324 is an analogue IC, and an opamp - which can be used as a basic comparator, but it isn't one. Comparators are analogue ICs as well.
Old 2nd August 2009, 02:36 PM   #7
Default confused about lm324
i just confused about lm432 because i got a information about lm324 like this in attachement. if it wright or wrong? if it wrrong in attachement plz explain abot it.
Old 2nd August 2009, 03:34 PM   #8
While that document seems mostly wrong and very poorly written, even it repeatedly says that the LM324 is an opamp - basically it's four 741's in a single casing.
As I've said, you can configure an opamp as a comparator, but it's not actually one.
For a comparaor, check the LM311, LM339, LM393 - there are loads of different ones.
Old 2nd August 2009, 05:39 PM   #9
Default sensor circuit lm324
k thanks. in my line following robot, the sensor part have the lm324. i attach the basic block diagram it, bt in this lm 324 is act as comparator.....if lm324 act as a comparator in sensor?
Old 2nd August 2009, 07:25 PM   #10
A block diagram doesn't really show anything, as the block is labelled 'comparator' presumably the opamp is configured as one?.
Old 2nd August 2009, 07:55 PM   #11
Why not just use one like Nigel said
be80be is online now
Old 8th August 2009, 07:53 PM   #12
Only reason I can see is, if one needed the other opamps in the LM324 package as "opamps".
Maybe someone can point pavithrams to good tutorials on comparators vs opamps. Something like this: http://www.analog.com/static/importe...als/MT-084.pdf
Ken
KMoffett is offline
Old 10th August 2009, 02:39 PM   #13
I don't know what the libraries are like in your area, but when I started looking for library books about beginning robotics in my area I found several that went into a lot of detail about building line followers. Kind of frustrating since that wasn't what I wanted, but a good resource if it is what you want. There was even one that was only about building line followers, and gave full details on every aspect, the housing, drivetrain, electronics and power supplies, where to get the stuff and how to build it, that one was called Robot Building for Beginners by David Cook. But there are several others if you can't find that. His website gives a lot of the details if your interested in that one: Robot Room - Sandwich, The Line-Following Robot
-Paul
Triode is offline
Old 20th August 2009, 08:57 AM   #14
Default Need Help Urgent
Hi friends,
There will be two parts to this system: a mouse shaped part, Jerry, and a cat shaped part, Tom. Both will be mounted with sensors and motors. They will communicate with each other, and Tom will chase Jerry. Tom will not be equipped with any sensors other than the sensor to detect Jerry, so that he bumps into walls and other objects (hardware will be protected) as in the cartoon. Jerry may or may not have other sensors to prevent him from crashing into objects, but will have a sensor that detects Tom so he goes in a different direction. The two might also communicate so that Jerryís velocity is always greater than Tomís.
This s synopsis of my project. Can anyone help me,like how can these 2 robots communicate. It would be great if u give some ideas how i can proceed this project..
vishnupsna is offline
Old 20th August 2009, 04:34 PM   #15
Its an interesting idea, but you're off the topic of the thread.
-Paul
Triode is offline
line, microcontroller, robot
need ckt for line following robot anand_jain Robotics Chat 16 10th May 2009 08:17 PM
Line following robot need help PLS!!! cs342 Robotics Chat 0 28th April 2009 10:12 PM
Line Following Robot Omar.M Robotics Chat 24 16th December 2008 10:28 AM
line following robot ahmedragia21 Robotics Chat 13 17th March 2008 12:20 AM
Line Following Robot loytp Electronic Projects Design/Ideas/Reviews 4 19th March 2006 06:14 AM
