Hi guys, what do you recommend for a suction pump which is able to hold a weight of 3kg on a glass wall? ![]() Best that the pump is light but possess strong suction power. | |
If your suction pump could pull a perfect vacuum then you would need a suction cup with an area of 3cm to hold 3kg. With a cup of 30cm area (6cm diameter) you would only have to suck out 10% of the air. It is the cup size that matters (where have I heard that before?). Mike. | |
Mmm, we have the suction cups you mentioned. Right now we are worried about our pump because we are unsure what kind of pump to use. Brand? Model? I am a noob, sorry | |
here you some to look at Miniature Vacuum Pumps measure as small as 37 x 55 mm., Clark Solutions | |
TEOSUC, Does the pump need to run continuous, or intermittently (minutes?...hours?...days?) ken PS: It might help if you keep all of this project Wall Climbing Robot in one thread. Spreading it out makes helping with your overall problem difficult.
__________________ "To invent, you need a good imagination and a pile of junk." Thomas A. Edison (1847 - 1931) Last edited by KMoffett; 29th July 2009 at 05:22 PM. | |
| climbing, pump, robot, suction, wall |
| CAD software recommendation | Eugenn | General Electronics Chat | 3 | 25th July 2009 08:02 AM |
| LCD Recommendation | BuffaloEngineer | Datasheet/Parts Requests | 2 | 26th January 2009 04:49 AM |
| Parts count vs. parts cost - Manufacturing question | mdwebster | Electronic Projects Design/Ideas/Reviews | 6 | 30th April 2008 10:58 PM |
| good recommendation?? | shermaine | General Electronics Chat | 8 | 30th March 2007 09:27 PM |
| I need recommendation to LCD | zofiof | Datasheet/Parts Requests | 0 | 12th July 2004 07:35 PM |
