Old 19th June 2009, 01:00 PM   #1
Default servo motor
which type receive servo motor signal
malik_shoaib is offline
Old 19th June 2009, 01:11 PM   #2
I dont understand your statement but....
The normal signal for driving R/C servos is a pulse with a width of 1 to 2 mS with a frame rate of 50 mS...
The servo is normally centred at 1.5mS
Eccentric millionaire financed by 'er indoors
Chippie is offline
Old 26th June 2009, 12:41 PM   #3
Forgive me but isn't the "frame rate" or "period" normally 20 msecs (sometimes as low as 3 or 4 msecs for newer generation digital servos)?
Mike, K8LH is offline
Old 26th June 2009, 02:48 PM   #4
Doh... yes my mistake... Must have been having a Homer moment
I was thinking 50 Hz which is 20msecs...
Thanks for pointing that out...(where's the 'embarrassed' smiley? )
Chippie is offline
Old 27th June 2009, 07:42 AM   #5
It's specced at a MAX of 20mS. Actually you can go longer as the brain in the servo is a sample and hold based on the pulse HI period only. I've used up to 40mS with no problems. If you go much longer than that the servo brain goes into low power "limp" mode and powers down its hbridge.
You can go LESS than 20mS with no probs, I made a 4 servo system that used 2.5mS events to sequence the 4 servos so the total period for any 1 servo was 10mS.
Mr RB is offline
motor, servo
Servo motor uaefame Robotics Chat 41 4th December 2008 12:02 AM
data for servo motor vdd Robotics Chat 13 16th October 2007 10:54 PM
DC motor, Servo Motor or Step Motor ? wcz Electronic Projects Design/Ideas/Reviews 1 29th June 2005 02:41 PM
servo motor help! show-boat Micro Controllers 7 14th November 2003 04:33 AM
servo motor droid Datasheet/Parts Requests 2 18th September 2003 02:40 PM
